Help with my Elemack Spyder dolly
#1 George Odell
George Odell
  • 32 posts
Posted 13 August 2012 - 09:35 AM
Hello to all.
Picked up an Elemack Spyder dolly on Saturday from a local production house. Has not been used in some time and, unfortunately, has been stored for a few years in the dank basement of a house.
Needless to say, I have my restorative work cut out for me before I can use it. However, I'm up to the task and eager to put this baby back to it's original glory.
But... I can use some help and advice from anyone out there who either owns one or has some experience using it.
Here are my questions:
1) When you pump up the column, which one should raise up first?
2) There is a black plastic knob atop the "oil tank". I assume this is the fill port (?). Should this unscrew easily? Mine is on way too tight and I'm afraid it will snap off. Did they make a better replacement for this at some point?
3) Can anyone recommend the type/brand of hydraulic oil it uses?
4) This one has only the studio wheels. Do you recommend I search for the OEM bogey wheels or go with a skateboard arrangement. Replacing the wheels seems like a much harder/time consuming operation IMHO.
What's the real deal with the oil leak reputation the Spyder has? Where does it leak and how bad is it? I was told most leaks are from the operator continuing to pump after the column is fully extended thereby causing pressure to build up and pop a seal.
Comments, please.
Thanks for any help you can provide.
Edited by George Odell, 13 August 2012 - 09:39 AM.
#2 Donald Mitchell
Donald Mitchell
Posted 28 August 2012 - 05:02 AM
You should contact Tony Covell in the UK - an expert on Elemack dollies.
Tonycovell@talktalk.net
#3 George Odell
George Odell
  • 32 posts
Posted 13 September 2012 - 10:44 AM
Actually it's Phillip Covell, his son, who works on them. Thanks to his help I'm well on my way to restoring this old girl.
