K3 in NYC
9 replies to this topic
#1 Rudy Velez Jr
Rudy Velez Jr
  • 225 posts
Posted 14 August 2012 - 04:09 PM
Are there any good places to get a K3 serviced in NYC? Overhauled or just plan old checkoed out. I just got my K3 which I brought from eBay from Moscow and I noticed that when I presed the trigger on the camera the lens would look fogged up but then when I pressed the trigger some more it this fog would go away and then reappear. Also looking through the viewfinder there is like some minor black specs but I am lead to believe that is nothing but a sign of old age( made in 83 based on serial number). Does my lens need to be cleaned? Also my trigger is like loose? Can I tighten this or no? Lastly what are the types of lenses I can get for this camera. Yes I know I can mount any M42 type of lens to my K3 but what purpose would a: 50mm lens do? 135mm lens? 17mm lens? 24 or 25mm lens?
#2 Charles MacDonald
Charles MacDonald
  • 1157 posts
  • Stittsville Ontario Canada
Posted 14 August 2012 - 06:51 PM
The M42 lens mount was used for the Pentax and Practica 35mm SLR cameras. as such, the available lenes are always a bit "long" compared to the selection for a camera made for 15mm Movie lenses.
That said, the use of the various focal lengths are exactly the same. A 50mm is a Modest Telephoto on a 16mm camera, and longer lenses are even more telephoto like. You will want a good tripod if you try a 400mm.
The Soviets did make an 8mm lens which acts as a fish eye on a 35mm Camera but is supposed to be a fairly good wide angle on the Soviet 16mm cameras. the widest common lenes for the pentax were generally a 28mm or so, which is about the length that a Filmo might come with as its basic lens. (25mm is the norm for a filmo)
#3 Dom Jaeger
Dom Jaeger
  • 1817 posts
  • Melbourne, Australia
Posted 14 August 2012 - 09:04 PM
..I noticed that when I presed the trigger on the camera the lens would look fogged up but then when I pressed the trigger some more it this fog would go away and then reappear. Also looking through the viewfinder there is like some minor black specs but I am lead to believe that is nothing but a sign of old age( made in 83 based on serial number). Does my lens need to be cleaned?
The image in your viewfinder is a reflection off a spinning mirror behind the lens. If the image is going foggy then clear it's probably because the mirror surface has some damage. It's actually polished aluminium rather than a proper mirror, and attempts to clean it can easily cause damage that reduce its reflectance. If you unscrew the lens you can inspect the mirror surface.
The other possibility is that the mirror isn't spinning flatly, so the image to the viewfinder will go in and out of focus (and seem to vibrate) as the mirror spins.
The expense of fixing either of those problems really isn't worth it for a hundred dollar camera.
The black specks will be in the viewfinder optics or on the groundglass, not the lens. They won't show up on the film itself. You can't really see how dirty the lens might be through the viewfinder. Excessive dust or fungus in the lens will just reduce the image clarity and contrast. If you unscrew the lens and hold it up to a light you can check how clean it is.
#4 Miguel Loredo
Miguel Loredo
  • 143 posts
Posted 15 August 2012 - 06:13 AM
Where can I check the manufacturing data of my K3 according to the serial no.? I have recently bought mine and am going to try it in the next days.
Thanks in advance.
#5 Rudy Velez Jr
Rudy Velez Jr
  • 225 posts
Posted 16 August 2012 - 09:14 PM
Hey My camera came with a bunch of the filters can anyone tell me what they are for? When it would best to use them?
If someone could just link me to something dealing with this topic of lens filters.
#6 Miguel Loredo
Miguel Loredo
  • 143 posts
Posted 17 August 2012 - 09:46 AM
Nope without knowing what type of filters are they B)
#7 Charles MacDonald
Charles MacDonald
  • 1157 posts
Posted 17 August 2012 - 11:20 AM
The K-3 sets I have seen on E-bay seem to come with filters for both colour and B&W shooting. I am not sure if the soviets had there own set of codes for the colours.
Typically they seem to come with the RED and YELLOW B&W filters (darken the sky to make clouds stand out) and what looks like an 85 (salmon coloured) used to shoot tungsten film in daylight. But I am not sure as I have not seen any up close.
#8 David C Connolly
David C Connolly
  • 9 posts
  • Houston TX
Posted 20 November 2012 - 09:17 PM
2012 NCS Products | 1-718-395-3424 | New York, USA
#9 Will Montgomery
Will Montgomery
  • 2106 posts
  • Dallas, TX
Posted 23 November 2012 - 09:36 PM
Du-All camera in NYC, near Madison Square Garden does great work with these. They modified mine to Super 16mm including widening the viewfinder.
I rented some lights from them last time I had a shoot there, good bunch of guys.
#10 Rudy Velez Jr
Rudy Velez Jr
  • 225 posts
Posted 27 January 2013 - 02:38 PM
Du-All is great! Right by Penn Station which is a primo location, they sell cameras,fix cameras, and even transferred my 8mm film.
