RC Helicopter
#1 Andre Labous
Andre Labous
  • 39 posts
  • Neptune Beach, FL
Posted 16 August 2012 - 09:20 PM
I'm struggling the decision on what camera to put on RC helicopter for aerials. In your opinion is codec more important than field of view.
PMW-200 --3 1/2" cmos sensor. 422 50mbs. Wide is around 30mm (converted to 35mm) and with 0.6 wide angle adapter 18mm
FS-700 ----- super 35 field of view. codec AVCHD 420 . Slo mo capability. Wider lens options.
Scarlett------- whatever
5D------- h264. Blah
#2 Darren Levine
Darren Levine
  • 24 posts
  • Astoria, NY
Posted 17 August 2012 - 03:19 PM
youre missing the most important piece of info... what is the max load capacity of the heli? i've worked with remote heli pilots and less weight is much preferred. i don't know if there is a nailed down formula, but i'd venture a guess that putting 1/2 or less of the max load into the heli is a good weigh to be at. though since you're label is RC Helicopter i'm sure you already have a handle on that ;)
im eyeing the pmw200 to replace my ex1, but not sure if its significant enough of an upgrade. you might want to look into the black magic cinema camera. has a form factor that i think will really fit helicams nicely. wider lenses are a bit rarer for it, but the tokina 11-16 or the sigma 8-16 should get you as wide as your heart desires. and it can record uncompressed at 2.5K or prores, or dnxhd, all onboard, no external recorder, for $3000. should be shipping this month, but rumors are large backorders
Edited by Darren Levine, 17 August 2012 - 03:21 PM.
#3 Brian Drysdale
  • 5287 posts
Posted 18 August 2012 - 01:48 AM
You should check on how legal your RC helicopter is, the FAA is currently looking at aerial work using these. Here are some associated documents
http://www.dvinfo.ne...der-8130.34.pdf
http://www.dvinfo.ne...rations-nas.pdf
Edited by Brian Drysdale, 18 August 2012 - 01:49 AM.
