Canon C300 with Canon L lenses vs. 5D Mark 3 with Zeiss primes
#1 Trent Watts
Trent Watts
  • 11 posts
Posted 21 August 2012 - 12:44 PM
I've got a gig coming up where I have a budget to rent some equipment. I'm going to use one of the combinations above. I already own the Canon L lenses. The final video will be displayed in a movie theater. The final resolution will be 1920 x 1080. But I am wondering basically about the 4k sensor with l lenses vs a full frame sensor with a set of zeiss prime lenses. the video will be in black and white, so what do you all think will give me the sharpest image, beautiful boca, and the most dynamic range?
#2 Phil Rhodes
  • 12173 posts
Posted 21 August 2012 - 01:36 PM
Dynamic range is independent of lens choice, unless you want to start taking into account variances in flare and veiling which might appear to extend effective range a little by flashing the image.
Bear in mind it may be a sensor that's 4000 photosites wide, but it isn't a 4K output.
What camera would you be using which has a "full frame sensor" and Zeiss primes?
#3 Trent Watts
Trent Watts
  • 11 posts
Posted 21 August 2012 - 07:52 PM
I'd be using the 5D Mark 3. Another thing I'm worried about with the C300 is ease of use with my Zacuto Shoulder Mount and Glidetrack 30" SD
#4 Phil Rhodes
  • 12173 posts
Posted 21 August 2012 - 08:24 PM
Well, the 5D mark 3 and the C300 are wildly different things, at totally different price points. I haven't closely investigated the imaging performance of the 5D3, but if the codec is of similar performance to that in the 5D2, that'll kill your sharpness long before the lenses become a factor even if the sensor is free of aliasing.
I haven't shot tests and therefore you should, but I would expect the C300 to outresolve the 5D3 comfortably.
#5 Trent Watts
Trent Watts
  • 11 posts
Posted 23 August 2012 - 10:36 AM
Thanks for everyone's advice, I've decided to go with the C300 since I tested it out yesterday and as long as I don't use a rail system, it works very well with my Glidetrack!
