Question to gaffers
11 replies to this topic
#1 Artyom Zakharenko
Artyom Zakharenko
  • 65 posts
  • London, Amsterdam, Moscow
Posted 10 September 2012 - 08:23 AM
Hi there guys
Last week i was shooting a video, our gaffer hang a 5K tungsten (build by Strand) in the studio, looking 45 degrees down. The lightbulb litterly exploded, broke the lens and burned the chimera. Now there's a discussion between the lighting rental company and my gaffer about whose fault it was.
1. The rental company claims the units are not supposed to hang high, looking down, because the heat in the unit can't get out that way.
2. My gaffer claims that those are studio lights, build for studio situations, including the possibility to hang them high and face down. Besides, the unit wasn't hanging straight down but 45 degrees, it had room to release the heat. The lamp was on for 5 minutes before it exploded.
Does anybody have experience with this?
Thank you
Artyom
Edited by Artyom Zakharenko, 10 September 2012 - 08:27 AM.
#2 Jon Rosenbloom
Jon Rosenbloom
  • 713 posts
Posted 10 September 2012 - 09:40 AM
I'm not a set electrician, but I think the rental house is rather full of it. You can't point them down 90 degrees; 45 should be fine. Lights are hung higher than set walls, and they shine down.
To me, it sound like someone left his fingerprints on the bulb. The oil boils and causes the glass to fail. So, the rental house could blame the crew for that, but the pointing down argument is f-ridiculous.
#3 Adrian Sierkowski
  • 7374 posts
Posted 10 September 2012 - 11:39 AM
I agree 100% with Jon, though I'm not gaffer, I've had plenty of 5Ks are about 45 degrees tilt plenty of times.
#4 Rex Harris
Rex Harris
  • 9 posts
  • UK
Posted 10 September 2012 - 02:03 PM
When I worked as a gaffer a few years ago we had plenty of those kind of lights hanging at 45 degrees and even higher angles than that with no problems. As Jon said above, oil on the bulb is the most likely culprit, especially given the time frame. Providing your gaffer didn't handle the bulb the rental company should have no argument.
#5 Matthew Parnell
Matthew Parnell
  • 289 posts
  • Electrician
  • Brisbane, Australia
Posted 11 September 2012 - 04:47 PM
Have had this happen with 5ks before smashing the lens and damaging the reflector. Usually its either oil on the globe, or a faulty globe(not uncommon). As for the rental house perhaps they should look at the manuals before pointing fingers. Would love to know the exact model of Stand, but in their manuals their 5k models can have a tilt angle of +90 -0- -90 degrees. PM me and I will email the manual I have if you want.
Edited by Matthew Parnell, 11 September 2012 - 04:49 PM.
#6 Justin W. King
Justin W. King
  • 50 posts
  • Electrician
  • New York, NY
Posted 18 September 2012 - 02:43 PM
Double Post
Edited by Justin W. King, 18 September 2012 - 02:46 PM.
#7 Justin W. King
Justin W. King
  • 50 posts
  • Electrician
  • New York, NY
Posted 18 September 2012 - 02:46 PM
Last I checked according to the Henry box book, the DPY globe has a tilt max of 45 degrees. Maybe I misunderstood, or strand lights use a different bulb, but if he was using it at a 45 degree angle, is seems he was pushing the bulb to it's limit. That doesn't mean that it was the cause, but it means thatit probably can't be ruled out immediately.
I've had a FFN MFL par64 lamp explode on me before, and shatter hot glass over the stage before, that no one had touched. Fortunately it was before the even and not after. So freak things do happen.
#8 Jaden Scholes_65655
Jaden Scholes_65655
  • 16 posts
  • montreal
Posted 29 September 2015 - 11:11 PM
Hey Matt I know the offer was for the postie do you think you could send me that manual or point me in the right direction. I'm a young electro and I'm just eager to learn as much as I can. Let me know if you can help me out.
#9 JD Hartman
JD Hartman
  • 1764 posts
  • Edison, N.J. U.S.A.
Posted 30 September 2015 - 05:56 AM
Might find this useful, strand archives: http://www.theatrecr...ve/contents.php
#10 JD Hartman
JD Hartman
  • 1764 posts
Posted 30 September 2015 - 06:03 AM
Hi there guys
Thank you
Artyom
Not supporting the rental house....
Depending on the construction of the body, in that position you are restricting the air flow somewhat.  Five minutes seems like a short time between strike and overheat, I'm voting for contaminated lamp.
#11 Mark Dunn
Mark Dunn
  • 2670 posts
Posted 30 September 2015 - 09:38 AM
It clearly says +/- 90 deg. in the Bambino manual. That covers a luminaire hanging from a grid.
#12 timHealy
timHealy
  • 1262 posts
Posted 09 October 2015 - 04:16 PM
Bulbs blow up for a variety of reasons and now the bulb is gone there is now way to prove if it was a faulty bulb or a shop technician with a dirty thumb or one of the set electricians with a dirty thumb. Or perhaps the voltage was too high? Was there a voltage spike?
That's why productions carry insurance.
Sometimes shite happens.
Best
Tim
