What's a smoother conform: 50p to 24p or 60p to 24p
#1 Trent Watts
Trent Watts
  • 14 posts
Posted 10 October 2012 - 04:07 PM
I'm planning to use magic lantern's hdr video mode which interpolates frames with different iso's resulting in a higher dynamic range image when you combine them in post. You have to shoot at twice the frame rate to make it work, but of course canon dslr can't shoot at 48p. So what would be a smoother-looking conform to 24p (23.98): 60p or 50p. At first, I would think 50, but if that takes 1 frame out every second, then wouldn't it be better to spread 6 frames out over that same second?
#2 Trent Watts
Trent Watts
  • 14 posts
Posted 10 October 2012 - 04:09 PM
Actually, I should be asking, what's smoother between 30p to 24p and 25p to 24p.
#3 Brian Drysdale
  • 5281 posts
Posted 10 October 2012 - 05:29 PM
Usually they just play the 25fps at 24 fps, the noticeable difference is in the sound pitch, although the running time also increases.
