which new charger for Beaulieu 4008zm ll
Beaulieu 4008 charger
#1 Jon Rat
Jon Rat
  • 14 posts
Posted 09 December 2012 - 10:25 AM
Hi all,
I've just acquired a second Beaulieu 4008, I was going to convert it to external battery pack but as it comes with a charging block and apparently re-celled battery I'm thinking I might try and make it work as is.
So what I'm lacking is the 7.2 volt charger, can someone advise on what I should look for regarding Ampage output etc- would these Ansmann chargers be ok? (charging current 900mA):
www.ebay.co.uk/itm/Ansmann-RC-Car-7-2v-6-Delta-Pro-Fast-UK-Battery-Charger-/251180558509?pt=UK_ToysGames_RadioControlled_JN&hash=item3a7b8728ad
Also, supposing I get a charger, can I use it with the old Beaulieu charging block and also could I use it to charge the battery via the camera itself through the input on the back?
Cheers all for any replies,
Jon
#2 Andries Molenaar
Andries Molenaar
  • 683 posts
  • Amsterdam
Posted 11 December 2012 - 07:49 AM
I use a simple Ansmann which can do all type of assemblies of NiMh and NiCd. It works just fine.
And I use a advanced one which can do drip charge and takes 12, 100-240 volt input.
Both have swapable 3.5mm connectors who just go into the camera or the external holder.
