Batch processing with Photoshop?
#1 Patrick Cooper
Patrick Cooper
  • 729 posts
  • Occupation:Other
Posted 06 January 2013 - 10:47 PM
I have a folder containing 400 JPEGs for assembling into a time lapse sequence. Although the stills are in the 16:9 aspect ratio, they do need a little bit of cropping on the bottom of the frame to improve the composition. Ive never done batch processing with Photoshop before. How would I go about it with version CS4? Whatever command I use for batch processing, should I apply / execute this command before or after I click 'Save'?
#2 Paul Bartok
Paul Bartok
  • 209 posts
  • Occupation:Cinematographer / DP
Posted 07 January 2013 - 08:32 AM
Do you have After effects?
Photoshop:
File> Scripts> Image Processor
This will allow you to batch edited images to re-size, reformat and also apply actions to each JPEG, the action can be anything you want to make if you desire.
After Effects:
Easy import JPEG as a JPEG sequence. work away.
#3 Vobla Unsane
Vobla Unsane
  • 12 posts
  • Gender:Male
  • Occupation:Other
Posted 17 March 2013 - 07:29 AM
I usualy batch process images using irfan view - http://www.irfanview.com/
Love this app for quick previews of images (even raw's open swiftly), batch, other tasks. Lightweght, fast, free.
Cheers.
