Single perf 16mm film. Perf holes on the other side! Help
16mm loading film perf help
69 replies to this topic
#1 Vadim Trofymenko
Vadim Trofymenko
Posted 14 January 2013 - 07:26 AM
Hi, I'm trying to get used to load 400' film in darkness (on the light for now of course). But, when I got film from the can it looks like perf holes are on the other side of my magazine perf teeth and camera registration pin! What's wrong?
#2 Vadim Trofymenko
Vadim Trofymenko
Posted 14 January 2013 - 07:31 AM
#3 Matthew W. Phillips
Matthew W. Phillips
  • 1792 posts
Posted 14 January 2013 - 07:33 AM
If you have single perf film, you need to load it with the perf lined up with your camera's perf teeth. On my CP16, it is with the perf facing toward the bottom so I have to load it by feeling for the perf on the bottom and feeding it through the felt roller and out of the mag. Thankfully, I can load the rest of it in daylight. If your camera has two layers of perf teeth together, you might require to have two perf film.
#4 Vadim Trofymenko
Vadim Trofymenko
Posted 14 January 2013 - 07:37 AM
But the per holes are completely on other side of film stock!, as you can see on the picture. I can load only base outside.
I can't load emulsion outside.
#5 Mark Dunn
Mark Dunn
  • 2659 posts
Posted 14 January 2013 - 07:43 AM
I think you may have the film the wrong way round in the magazine. Turn the roll over. Are you sure you're not trying to load from the wrong side of the mag?
Could you post a picture of the entire mag, with the film placed as you have it now?
Edited by Mark Dunn, 14 January 2013 - 07:47 AM.
#6 Vadim Trofymenko
Vadim Trofymenko
Posted 14 January 2013 - 07:49 AM
If I'll turn roll over I will be able to get film stock holes into the perf teeth but it will be base outside and emulsion inside.
And yes, I'm sure it's a right side of the magazine.
Here's how it's done with 2 perf film
#7 Matthew W. Phillips
Matthew W. Phillips
  • 1792 posts
Posted 14 January 2013 - 07:52 AM
If you have a difficult camera that normally requires two perf but has one perf of teeth, you may have to respool the roll backward so you can have the emulsion facing the correct way for your camera.
#8 Vadim Trofymenko
Vadim Trofymenko
I think I will need film stock with perf holes on the other side. Is there some?
#9 Matthew W. Phillips
Matthew W. Phillips
  • 1792 posts
Posted 14 January 2013 - 07:54 AM
Spectra used to carry some 2 perf but its harder to find and limited.
#10 Vadim Trofymenko
Vadim Trofymenko
Good idea. Should I re-spool 400' of film in the changing bag each time I'm changing the reel?)
#11 Matthew W. Phillips
Matthew W. Phillips
  • 1792 posts
Posted 14 January 2013 - 07:55 AM
If you have to choose between that and either relying on 2 perf or replacing the camera then yes, I would respool in the changing tent
#12 Matthew W. Phillips
Matthew W. Phillips
  • 1792 posts
Posted 14 January 2013 - 07:56 AM
It wont slow down your set because you can have rolls pre prepped in your fridge long before the shoot.
#13 Vadim Trofymenko
Vadim Trofymenko
I guess that's my only option. Will I have tension problems after I re-spool film manually?
#14 Matthew W. Phillips
Matthew W. Phillips
  • 1792 posts
Posted 14 January 2013 - 07:58 AM
I dont think so. People do things like this all the time. Think of those who have 100 loads only and respool 400' loads and short ends down to daylight spools for cheap. They have a fine time doing it and they technically have to respool twice. Once to get it on the roll and again to reset the emulsion side.
#15 Mark Dunn
Mark Dunn
  • 2659 posts
Posted 14 January 2013 - 08:00 AM
Are you using a short end to practice with? If so, from what I can see of it in your pic, I think it has been rewound so that the perfs are now on the wrong side, Perhaps it has already been run once as a test. You will not come across this with fresh film. Strip it off the core, put the head end onto the core and rewind it. The perfs will then be correct.
You have what is called an A-wind at the moment, Cameras need a B-wind. A-wind is for print film and, I believe the Aaton minima camera and no other.
#16 Vadim Trofymenko
Vadim Trofymenko
Are you saying after I've got the shot I can't just drop film in the can and get to the lab? I have to re-spool it back again?
#17 Matthew W. Phillips
Matthew W. Phillips
  • 1792 posts
Posted 14 January 2013 - 08:02 AM
Mark could be right about this. I would definitely make sure before a major shoot. Get a real test roll that you intend to shoot. Even if its just expired stock from ebay. You need to have your flow sorted before project day.
#18 Vadim Trofymenko
Vadim Trofymenko
Hmm, that's strange. It was a newly packed film (expired). Kodak Vision 500T. 16 N 1R. I don't think it was already used.
#19 Matthew W. Phillips
Matthew W. Phillips
  • 1792 posts
Posted 14 January 2013 - 08:03 AM
If it is the case that you have to go that route then yes, unfortunately, youd have to respool it back in the dark.
#20 Zac Fettig
Zac Fettig
  • 338 posts
  • Boston
Posted 14 January 2013 - 08:04 AM
It looks like b-wind to me. You can get A-wind, but usually only in 200' loads for the Aaton A-Minima.
