Safelight filter #8 vs #13 for 3383
#1 Richard Tuohy
Richard Tuohy
  • 482 posts
  • Daylesford, Australia
Posted 24 January 2013 - 06:21 PM
Hi all,
Kodak no longer sell the #8 safelight filter which is recommended for colour print stock. Their discontinuation notice of some time ago suggested #13 as a replacement. I am using the #13, which is very dark. If you look at the specificaitons for these two filters, the #8 has greater transmission at the apporox 600nm part of the spectrum. Does anyone know for sure whether the effect of the #8 over the #13 is a brighter light to work under?
Here is the kodak spec page on safelights:
http://www.kodak.com...0845/ti0845.pdf
cheers,
richard
#2 Brian Pritchard
Brian Pritchard
  • 330 posts
  • Rushden UK
Posted 27 January 2013 - 04:10 AM
According to the Kodak data sheets the safelight needs to be at 590 nM; looking at the safelight datasheet I would say that the #13 is a darker version of the #8. Can I suggest that you use a brighter bulb and do the coin test to check on the fogging?
Brian
#3 Dirk DeJonghe
Dirk DeJonghe
  • 612 posts
  • Kortrijk,Belgium
Posted 27 January 2013 - 12:00 PM
I found that this keychain LED light did not fog Kodak ECP2 color positive print film when fitted with the yellow LED.
http://www.photonlig...ain-flashlight/
