The small hi-end zooms comparison
#1 Haris Mlivic
Haris Mlivic
  • 55 posts
  • Stockholm
Posted 25 January 2013 - 08:46 AM
Hello everybody!
I'm shooting a commercial and need to pick one of the three 15-40/45 zooma available. Does anybody have any experience with either one of theese?
The current Arri Alura/Fujinon Lightweight zoom 15,5 - 45mm
The older Arri/Zeiss LWZ-1 15,5-45mm
Angenieux Optimo Zoom 15-40mm
Any thoughts would be much appreciated! Thanks!
#2 Mathew Rudenberg
Mathew Rudenberg
  • 252 posts
Posted 25 January 2013 - 03:07 PM
The only one of these I've used is the Optimo - that being said I've used it a lot (3 seasons, 3 movies) and it's pretty reliable/sturdy.
Softer then a prime of course, little cooler then a Cooke S4. Definitely a little vignetting on the wider end (if you play with the iris between 4 and 2.6 you can see that only the center of the frame gets brighter) Of course I do kind of like a little vignetting although that's easy to add in post.
All of that is pretty much what you would expect from a lightweight zoom. I would prefer to use other lenses if I could but if you need a zoom you can hand hold or to put on a 3d rig it's a good choice.
#3 Haris Mlivic
Haris Mlivic
  • 55 posts
  • Stockholm
Posted 26 January 2013 - 05:49 AM
Thanks Mathew!
Yeah I would definitely use other lenses too, but we're shooting everything handheld on the wide-side with a tight schedule (surprise) :)
Can't belive how little comparison-info there is on these lenses, you would think somebody on the internet would have compared them by now. Maybe I'll have to do a proper test...
#4 Tebbe Schoeningh
Tebbe Schoeningh
  • 117 posts
  • Buenos Aires, Berlin
Posted 27 January 2013 - 09:12 PM
Thanks Mathew!
WOuld be great to see some proper test comparing those. Would you share?
Thanks!
