Viewfinder shows dark spots when closing aperature
#1 Matthew W. Phillips
Matthew W. Phillips
  • 1792 posts
Posted 25 January 2013 - 07:11 PM
I received my first CP Ultra T prime today and I love how sharp it is. However, I was concerned when I noticed that when I close the aperature, I see black spots, almost like some kind of dirt, scattered around the frame. I thought it was the lens until I popped in the stock Angenieux and noticed it did the same thing.
Anyone know what is causing this?
#2 Gregg MacPherson
Gregg MacPherson
  • 1931 posts
  • New Zealand
Posted 25 January 2013 - 07:25 PM
Evenly distributed over the frame?
When you stop down you will see the ground glass texture.
#3 Matthew W. Phillips
Matthew W. Phillips
  • 1792 posts
Posted 25 January 2013 - 07:30 PM
Its more prominent in some areas than others
#4 Gregg MacPherson
Gregg MacPherson
  • 1931 posts
  • New Zealand
Posted 25 January 2013 - 07:35 PM
If you put a sheet of paper on the wall, illuminate that, go full frame, stop down, how does it look? You could blow the ground glass off a bit with your Rocket bulb stringe first.
#5 Gregg MacPherson
Gregg MacPherson
  • 1931 posts
  • New Zealand
Posted 25 January 2013 - 08:26 PM
Or if it's daytime in Sacramento just point it at the sky.
#6 Matthew W. Phillips
Matthew W. Phillips
  • 1792 posts
Posted 25 January 2013 - 08:54 PM
Cleaned up the path of the viewfinder, from inner glass to ground glass and now everything looks fine. Thanks Gregg.
