Is the ARRIFLEX 416 Plus HS louder than the other models at 24 FPS?
arriflex 416 plus hs arri super16 sound level
9 replies to this topic
#1 Charles Zuzak
Charles Zuzak
  • 74 posts
  • Pittsburgh, PA
Posted 28 January 2013 - 06:14 PM
For those of you who've actually used it, is the ARRIFLEX 416 Plus HS louder than the regular speed range 416 models? The former is rated at 29 dB while the latter two are 20 dB. However, unless I'm misinterpreting the specification, I suspect the sound level measurement is referring to operation at the top speed (150 fps vs 75 fps). Or does it actually make more noise at standard frame rates like 24 fps?
#2 Adrian Sierkowski
  • 7485 posts
Posted 28 January 2013 - 07:44 PM
From my experience on the SR3s, yes, HS models are louder even at normal speeds. It makes sense, when you think about it; as they are built differently in order to accommodate the higher speeds.
  • 1
#3 Charles Zuzak
Charles Zuzak
  • 74 posts
  • Pittsburgh, PA
Posted 28 January 2013 - 08:31 PM
Sure, but wouldn't most of the noise generated come from the film going through the gates? In that case, wouldn't the sound levels be negligible in difference at that speed? I could understand 75 fps vs 150 fps though...
Edited by Charles Zuzak, 28 January 2013 - 08:31 PM.
#4 Adrian Sierkowski
  • 7485 posts
Posted 28 January 2013 - 08:35 PM
It would come through the gate, but not necessarily be caused by the gate. All the rollers and the movement ect will also effect it; and it may even be a diff designed gate. Again, I'm going off of the SR3s i'm used to. I'd honestly just give a call up to Arri to find out for certain.
  • 1
#5 Dom Jaeger
Dom Jaeger
  • 1811 posts
  • Melbourne, Australia
Posted 29 January 2013 - 12:41 AM
I haven't had my hands on a 416 but I'd agree with Adrian, it's a function of high speed designs that makes them noisier. The high speed SR3 is rated at 27 dB compared to 20 dB for the standard. Noise is always measured at sync sound speeds (since noise at high speeds is kind of irrelevant.) I suspect with SR3s the noise variation is mainly due to the pressure plate design in the high speed mags, which is quite different from the standard ones. Something similar would be happening with the 416.
  • 1
#6 Charles Zuzak
Charles Zuzak
  • 74 posts
  • Pittsburgh, PA
Posted 29 January 2013 - 10:41 AM
Great explanation, Dom!
#7 Charles Zuzak
Charles Zuzak
  • 74 posts
  • Pittsburgh, PA
Posted 22 April 2013 - 11:54 AM
I found an answer directly from ARRI:
http://www.arri.com/...n&file_uid=1093
Page 22 details the sound pressure levels @ 24 FPS.
Likely due to the reasons you guys have outlined above, it is indeed more loud at normal run speeds.
#8 Michael T Gardner
Michael T Gardner
  • 15 posts
Posted 18 February 2014 - 03:47 AM
Now would the 27dB with the SR3 be considered too loud to record audio with? Would a HS model take a mag from the Advanced version?
#9 Brian Drysdale
  • 5281 posts
Posted 18 February 2014 - 04:25 AM
It really depends on the nature of the production, 27dB is roughly the same as 1970s 16mm cameras. Noise pick up depends how closely the subject is miked, the acoustics of the room and how close the camera is to the microphone. You should have a barney handy, although they used to make blimps for the early 16 SRs for use on dramas.
#10 Dom Jaeger
Dom Jaeger
  • 1811 posts
Posted 18 February 2014 - 09:37 AM
A normal mag will physically fit on a HS camera but it's not recommended to interchange them. For one thing the HS camera flange depth is slightly different to accommodate the different HS mag pressure plate design. I don't think it would be catastrophic though.
Also tagged with one or more of these keywords: arriflex 416 plus hs, arri, super16, sound, level
