Tri-x Reversal Coming Out Negative. What's Wrong?
Tri-x super 8 home processing
#1 John Raftery
John Raftery
Posted 31 January 2013 - 12:38 AM
Hello,
I'm trying to process Tri-x super 8 in a Morse G3 tank for the first time. Except for a couple frames at the beginning and end of the roll- it's all coming out as negative. What point in the process could I be messing up that's causing this? Does it sound like insufficient re-exposure?
Thank you in advance for your advice. I haven't posted on this forum before but I've been reading it for a while and I really appreciate the resource.
#2 Brian Pritchard
Brian Pritchard
  • 332 posts
  • Rushden UK
Posted 31 January 2013 - 04:01 AM
The basic stages in reversal processing are as follows:
Ist Developer - produces a negative image
Bleach - removes the negative image
Re-exposure - fogs the residual positive image
2nd Developer - produces the positive image
Fixer removes any residual silver halide.
Obviously I have left out steps such as washes and rinses and clearing bath
If you are left with a negative image it sounds if your bleach has not worked. Insufficient re-exposure would not give a negative image you would probably get a weak (thin) positive image.
Brian
#3 John Raftery
John Raftery
Posted 31 January 2013 - 10:36 AM
Thanks Brian! I'll try lengthening my bleach time and if that doesn't do it I'll make a new batch of bleach.
#4 Richard Tuohy
Richard Tuohy
  • 482 posts
  • Daylesford, Australia
Posted 31 January 2013 - 05:43 PM
Hi John,
the bleach is cheap, the film isn't. Mix fresh bleach before you re-test.
Assuming you are following the correct sequence as Brian pointed out, if the bleach was inadequate you might expect a very dark negative to entirely black film. This is because the second developer, assuming it was good, should have developed the remining Silver halide, thus producing the 'positive' silver image. This should mean that you have both the originally developed negative silver image and the now second developed positive silver image.
So, was the negative quite dark?
richard
#5 John Raftery
John Raftery
Posted 31 January 2013 - 07:20 PM
A couple minutes more in the bleach is all it took, it's definitely a positive now. I have't projected it but it looks pretty good through the eye loupe. The negative didn't look particularly dark but I guess that was it.
Thanks, guys!
