Using seamless backdrop as bounce
seamless backdrop bounce lighting
11 replies to this topic
#1 MICHAEL TAPP
MICHAEL TAPP
  • 18 posts
  • 2nd Assistant Camera
Posted 06 February 2013 - 08:23 PM
Have you used a seamless backdrop as a bounce? I am thinking about using a 5x7 seamless backdrop as a bounce instead of a 4x4 diffusion frame since the seamless is bigger and should yield a softer light than a 4x4.
Have any of you tried using a seamless backdrop as a bounce? I'm not sure how reflective a seamless backdrop can be. Just throwing this out there before testing it out on a job. Any input will be greatly appreciated!
#2 robert duke
robert duke
  • 438 posts
  • Grip
  • southeast USA
Posted 07 February 2013 - 12:07 AM
5x7 is bigger and softer. white bounce is white bounce. the bounce return will be a little harsher than beadboard but softer than foamcore, because the seamless paper has a shiny texture to it. you may also want to meter the opposite side to find out a relative transmission rate. (subtract the light going through the paper from the light hitting it, and measure the bounce.) totally unscientific, but it works.
for fun you might try color paper for color bounces
  • 1
#3 Adrian Sierkowski
  • 7485 posts
Posted 07 February 2013 - 09:46 AM
Anything you want to use can certainly be a bounce. You may get some odd looks from some people on set; but screw it; if it works it works.
  • 1
#4 MICHAEL TAPP
MICHAEL TAPP
  • 18 posts
Posted 07 February 2013 - 11:07 AM
Thank you all for the reassurance! We have a collapsable seamless backdrop: http://www.bhphotovi...ckground_5.html I'm not using paper, but that's a great idea Robert. It's a cheap way to get a cool or warm bounce.
I have to transport gear around NYC. Part of my reasoning is that it will be much easier to transport a collapsable seamless than a 5x7 piece of foamcore.
#5 Adrian Sierkowski
  • 7485 posts
Posted 07 February 2013 - 12:24 PM
I'm sure up in NYC you can probably get fabrics cut to size for super cheap. Just put some Grometts in them yourself and you'll have a travel collapsable fabric bounce kit... of course... be wary of how much heat you throw into the fabrics.
I used to this that in Phila, hit up fabric row, grab some like light rose tinted fabric and bounce a light into it to get a warmth-- a kin to using a cosmetic gel pack but softer. Size becomes an issue; of course; but can work well
#6 MICHAEL TAPP
MICHAEL TAPP
  • 18 posts
Posted 07 February 2013 - 01:47 PM
Very clever Adrian! Thank you for the tip.
How did you put the fabric on stands? Did you use the grommets to attach the fabric to a frame, and then attach the frame to 2 stands?
#7 Edward Lawrence Conley III
  • 192 posts
  • Los Angeles CA
Posted 07 February 2013 - 04:41 PM
It is just a name :)
use it as a backdrop and it is a backdrop
use it as a reflector and it is a reflector
#8 Edward Lawrence Conley III
  • 192 posts
  • Los Angeles CA
Posted 07 February 2013 - 04:44 PM
There are quite a few breakdown butterfly kits out there
http://www.bhphotovi...Top Nav-Search=
http://www.adorama.com/LSCR64SG.html
#9 Adrian Sierkowski
  • 7485 posts
Posted 07 February 2013 - 05:04 PM
Gromit and then I zip tie to a frame; it's simple.
Ed I'm in town; we need to grab a drink sometime!
#10 Jon Rosenbloom
Jon Rosenbloom
  • 713 posts
Posted 08 February 2013 - 12:37 PM
Seamless paper?? Highly impractical; it will rip in no time. Just get your hands on some bleached muslin. A 12'x12' piece folds up to almost nothing.
I remember once putting grommets in a 20'x20' shower curtain. My "professional opinion" is that by the time you've bought the grommet kit, set up the work station, hammered the thing out for an hour, and bashed a couple of fingers, you could have just rented one that was made in a factory.
#11 steven moreno
steven moreno
  • 1 posts
Posted 22 February 2013 - 04:44 PM
Where's the best place to buy muslin in LA?
#12 Edward Lawrence Conley III
  • 192 posts
  • Los Angeles CA
Posted 22 February 2013 - 05:27 PM
http://www.laraghouse.com
I haven't really checked prices but LA RAG house is really easy to deal with and they have all the textiles in house so no running around town.
