DaVinci Resolve 9 - Flicker Issues
color grading editing davinci resolve problem solving technical software help issues rendering
#1 Lane Lehman
Lane Lehman
Posted 21 March 2013 - 09:23 AM
Hello, I'm relatively new to DV and recently installed version 9 after coming from 8.2.  I've looked around on the net for problems regarding this issue and have basically hit a wall - the problems that most people have had were with the same anomaly I've been trying to deal with.
Problems:
Finalized file has a bar at the top of the video that flickers on and off. The entire frame will do this as well randomly throughout a clip.
Along with the above, say I apply a LUT and grade it, then render. In the final file the video flickers back and forth between the graded footage and the stock footage.
-- I haven't had any noise issues or anything of that sort, just random flickers --
Possible Solutions I've found and (or) attempted:
Upgrade to the latest Cuda Drivers - 5.0.35
Disable SLI (tried rendering with 1 GPU and still had problem)
Check frame rate to make sure the master matches the file
Tried rendering as multiple filetypes
Disable all audio
* there might be some others but they don't come to mind right away, what I did find is that a lot of the macos users that had similar problems needed an   OS update.
The footage was shot on a 60D, 1080p @ 24fps as a .mov
The media rendered, was rendered to a .mov along with a .#res file as well.
I've included my project settings below - feel free to point out anything that seem obviously out of place  ^_^
Along with that, here is a clip of the actual problem.
NOTE: The flickering at the end of the video is not the candle. You can also observe the bar at the top of the frame that spans horizontally while flickering.
http://lanelehman.co...01_MVI_9526.mp4
System Information:
Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120503-2030)
Processor: Intel® Core™ i7-3930K CPU @ 3.20GHz (12 CPUs), ~4.2GHz
Memory: 16384MB RAM
DirectX Version: DirectX 11
Display Devices:
Card name: NVIDIA GeForce GTX 560
Manufacturer: NVIDIA
Chip type: GeForce GTX 560
Display Memory: 4050 MB
Dedicated Memory: 978 MB
Shared Memory: 3072 MB
Current Mode: 1920 x 1080 (32 bit) (59Hz)
Driver File Version: 9.18.0013.0694 (English)
Driver Version: 9.18.13.694
Thanks for any replies I get here, I really appreciate the time taken to read all of this. My search for a solution to a working version of v9.0 continues!
#2 Adrian Sierkowski
  • 7492 posts
Posted 21 March 2013 - 01:53 PM
Lane, you're probably get much better answers over on Black Magic's own forums :
http://forum.blackmagicdesign.com/
#3 Lane Lehman
Lane Lehman
Posted 21 March 2013 - 02:20 PM
Thanks, these forums seem more populated so I thought I might take a shot.
Over there..  :mellow:
#4 Adrian Sierkowski
  • 7492 posts
Posted 21 March 2013 - 04:22 PM
They are; but it's much more for cinematography and cameras, lenses, lighting, ect, as opposed to the set up of color correction systems.
#5 Oliver Hadlow Martin
  • 102 posts
  • 2nd Assistant Camera
  • UK
Posted 22 March 2013 - 12:02 PM
There is a weird bug that has never been corrected in any of the versions of Resolve.
It requires that you set all frames to zoom very slightly otherwise for whatever reason they don't totally fill the frame when set at 1.000 it needs to be set to 1.002
Some will fill and some wont, it then introduces a flicker at the top of frame.
#6 Oliver Hadlow Martin
  • 102 posts
  • UK
Posted 22 March 2013 - 12:03 PM
Just looked at the video that is something totally different sorry! I've no idea why it's doing that.
#7 Lane Lehman
Lane Lehman
Posted 22 March 2013 - 11:29 PM
Thanks for all the help, I did end up.. updating to the latest nvidia drivers then just installing lite for now and everything works.
Still an odd issue though.
Also tagged with one or more of these keywords: color grading, editing, davinci, resolve, problem solving, technical, software, help, issues, rendering
