Hand processing
Kodak surveillance WL 2210
#1 tom kirkman
tom kirkman
  • 1 posts
Posted 22 March 2013 - 02:54 PM
This is my first post on here and I am pretty new to 16mm cinematography. Today I processed my first lot of black and white film, kodak surveillance WL 2210 which I bought from ebay, the results were a bit ropey and inconsistent. I processed it at my uni where we only have ID-11 chemistry but I can only find specs and times for processing this film using D-76 chemistry which from what I have read online is basically kodaks version of ID-11 but on the ilford process chart the times for the two are about 2 minutes diffrent depending on the iso at which you have shot. does anyone know if I should just follow the D-76 times but with ID-11 or if there is a equation to work out the correct time I need to use? or even if anyone has processed this film in ID-11 what times and temps you used.
cheers
#2 Matthew OConnell
Matthew OConnell
  • 4 posts
Posted 10 April 2013 - 09:51 AM
Hi Tom,
I also bought some of this stock off eBay. I had it processed at Alphacine in Seattle. They said it was a bit tricky, but no problem.
I would give them a call re. chemistry / timings etc. They are pretty helpful.
This stock, for the price, is pretty good I think. It didn't have the contrast of 7222 but it was good in low light and still looked nice.
Cheers, Matt
#3 Antoni Rudnicki
Antoni Rudnicki
  • 2 posts
Posted 11 April 2013 - 06:20 PM
Hi Tom
I hand processed about 8 rolls of WL 2210 so far in ID11 in a Lomo tank with good results.
Prebath in water 2 min @ 21 C
ID11 6 minutes @ 20 C
Stop bath 30 sec
Rinse 2 min
Fixer 5 min
Wash 2 min
Hypo 3 min
Wash 5 min
Photo flow 1 min
Dry
With timings only developer temperature is crucial - prebath is a higher temperature to warm up the tank.
cheers
Antoni
#4 Simon Wyss
Simon Wyss
  • 1491 posts
  • Basel, Switzerland
Posted 12 April 2013 - 02:44 AM
Omit the prebath. Useless
#5 Mark Dunn
Mark Dunn
  • 2658 posts
Posted 12 April 2013 - 06:00 AM
ID-11 and D-76 are identical formulations. Any difference is probably down to the manufacturers' recommendations for their own stocks. I would consider the timings to be interchangeable.
#6 steve waschka
steve waschka
  • 204 posts
  • Orlando, FL
Posted 18 April 2013 - 09:49 AM
what are you using to transport the film thru the bath? rewind, spiral tank? or are you literally "hand" processing in a bucket or tray?
