CINE MAGIC REVOLUTION LENS SYSTEM For Sale
LENS SYSTEM CINE MAGIC REVOLUTION
No replies to this topic
#1 Michael Ferguson
Michael Ferguson
  • 7 posts
Posted 25 March 2013 - 02:54 PM
CINE MAGIC REVOLUTION LENS SYSTEM   For Sale $30k Click Here .
REVOLUTION SYSTEM CONFIGURATIONS:
REVOLUTION+PL SWIVEL
REVOLUTION+MINI-PL SWIVEL
REVOLUTION+PL HORIZON TRACKER
REVOLUTION+MINI_PL HOR. TRACKER
REVOLUTION+BL BORESCOPE
REVOLUTION+MINI_PL BORESCOPE
MINI-PL LENS
The Revolution Lens System includes 9.8mm, 12mm, 16mm, 20mm, 24mm, 32mm, 40mm and 60mm Revolution lenses plus interchangeable "PL" mount for use with selected "PL" mounted prime and zoom lenses. The "T" stop range is T7.5 to T64. The "PL" mount at the camera end of the Revolution will accept one 40.5mm filter at the rear and two 40.5mm filters screwed into the front of the mount. The Revolution lenses can be filtered directly by attaching the 2" x 3" clamp on filter holder. This holder can be used either in a horizontal or vertical position on the lens. When using "PL" mounted lenses, filters can be attached to the front of the lens in the conventional manner.
NIKON TILT FOCUS ATTACHMENT and MODULE AXIS LOCK
PL LENSES
9.8mm PL 2" 0.5 lbs
12mm PL 1-3/4" 0.5 lbs
16mm PL 2" 0.5 lbs
20mm PL 3" 0.5 lbs
24mm PL 2-1/4" 0.5 lbs
32mm PL 2" 0.5 lbs
40mm PL 2" 0.5 lbs
60mm PL 2" 0.5 lbs
Revolution Borescope - PL and Mini PL
Revolution Large Snorkel - PL
Revolution Multi Mount Relay
Cine Magic International's new Revolution Lens System. It's the world's first snorkel lens system that allows live panning of the objective lens while maintaining a level horizon. The built in image orientation optics allow the image to be rotated to any position within a 360 degree circle. Spinning images can also be accomplished by continuously rotating the image rotation ring.
When using the Horizon Tracker module, the horizon can be set to the desired position and locked. This innovation allows the objective lens of the snorkel to be panned while the horizon remains in the level or dutched position that you have chosen. A six or seven inch diameter is all that is needed to achieve the 360 degree pan making this device ideal for tabletop or miniature shots!
The Dual Swivel module adds a second pan axis to the lens system. In this case, the horizon lock is not used. The horizon can be adjusted manually or electronically. The Preston FI+Z focus system available at Clairmont Camera, can be programmed to automatically correct the horizon while panning with the Dual Swivel module.
This ability to control the horizon angle while aiming the camera and snorkel at any angle, in any direction, gives the Revolution a distinct advantage over previous snorkel systems that limit the control over camera movement in order to maintain the horizon line. Whether using the Horizon Tracker module or the Dual Swivel module, infinite shooting angles can be achieved without requiring specialized and time consuming rigging equipment.
Michael Ferguson
System Associates llc
Film & Broadcast Television Equipment
Wanted and For Sale
623.937.0209 Office
623.451.4439 Mobile Device
