Four-Inch Diameter Drop-In UV Filter
#1 Glenn Brady
Glenn Brady
  • 329 posts
Posted 30 March 2013 - 03:56 PM
I've acquired a Century 3.5mm f/1.8 Extreme Wide Angle lens equipped with a filter holder that accepts filters four inches in diameter.  Typically, these lenses were supplied with a filter holder accepting readily available 4½-inch diameter filters and I've found no four-inch diameter filters (which are larger than the largest series filter of which I'm aware).  Does anyone know where I might get a four-inch diameter UV filter?
#2 Daniel Klockenkemper
  • 56 posts
Posted 30 March 2013 - 05:32 PM
Try your local glass supply or framing company and ask them to cut you a piece of museum glass in the size you need.
#3 Glenn Brady
Glenn Brady
  • 329 posts
Posted 31 March 2013 - 01:55 PM
Thanks.  That sounds like a comparatively inexpensive solution.
