Tiffen Pro Mist vs Smoque vs fog
tiffen filter pro mist smoque fog
#1 Joseph Chen
Joseph Chen
  • 5 posts
Posted 07 April 2013 - 05:33 AM
can anyone explain in details what are the exact difference between these filter?
and What filter was used in these images? if any.
  • 20239 posts
Posted 07 April 2013 - 10:46 AM
Tiffen Smoque (early 2000's) is like a heavy UltraCon, it reacts to light sources in the frame, creating a hazy glow, but is hard to see when there is no light in the shot.  Doesn't impact sharpness much.  The effect can disappear when someone blocks the light source in the frame for a moment and reappear once they clear.
Tiffen ProMist (mid-1980's) was a glass version of the briefly popular plastic Wilson SupaFrost (or SupraFrost, I've seen it spelled both ways) -- it softens the image a bit while causing highlights to glow.  Often combined with blacks specks (Black ProMist) to restore some loss of contrast.  Schneider makes a White Frost and Black Frost which are similar.  A Tiffen GlimmerGlass is basically a Black ProMist with silver specks instead of black.
Fog (various, mainly Harrison or Tiffen) dates back to the early days, before 1940 at least, but has been improved over the decades, but generally the design dates back now to the 1970's.  Mist particles cause highlights to glow.  In some ways, it wasn't designed to soften detail like a ProMist was, just fog the highlights, but the nature of the particles sprayed on a layer (I think sandwiched between glass) causes some blurring of detail / contrast loss, a milky effect... and that can get stronger depending on how the light hits the subject or filter... this inconsistency in effect/strength due to the older design is one reason why people prefer ProMist.  I've also found that the glow around lights can take on a blue-ish cast with Fogs, but are neutral with ProMists.  However, I think of Fog as a 1970's look and ProMist as a 1980's look and tend to use them accordingly.
It's hard to tell in manipulated b&w stills what filters could have been used.
"Tess" is a good example of the use of Fog filters:
#3 Joseph Chen
Joseph Chen
  • 5 posts
Posted 07 April 2013 - 10:58 AM
Thank you.
Any suggestion on what filter to you if my aim is to make similar to those pics, where the highlight is glowing? what strength?
#4 David Mullen ASC
  • 20239 posts
Posted 07 April 2013 - 11:13 AM
Anything for starters... you could even make your own net filters with some ultrasheer black pantyhose stretched tight over a filter frame or the lens, just shade the camera lens well to avoid a veiling flare.  You could also save it for Photoshop if you are just talking about stills.
#5 Joseph Chen
Joseph Chen
  • 5 posts
Posted 07 April 2013 - 06:38 PM
thank for your reply. i did use cellophane wrap a few times, but i will try stocking. i am trying to look for a crystal too, but  big one so i can shoot through.
