My potential Canon Scoopic MS + sound rec set up?
Canon Scoopic MS
#1 Rudy Velez Jr
Rudy Velez Jr
  • 225 posts
Posted 07 April 2013 - 05:07 PM
This is my scoopic ms set up on my tripod and with a few brackets holding my zoom h4n and chinon super 8 boom mic.
question1: what do you think of this set up?
question2: what type of PX battery would one of these Chinon super8 boom mics take?
question3: I have currently two sylvania sun guns(models 1 & II) how would I go about setting up these two powerful lights to provide light for my shoots. Is it safe to put a some shower curtain cloth over the light ( at least 6 inches away, from powerful light) to act as a diffuser. Is is possible to mount these lights to tripods, they have some screw threads and brackets . What type of lighting effect would result if I attached one of my sun guns to were I have the Chinon boom mic in the photos listed. I think i will post a picture of this later, to clarify.
Question 4: This MS is un modified by The Film Group so no crystal sync..Has or Does anyone have used a scoopic with a Crystal sync, if so, how does it effect the noise the camera makes while filming.
Although my camera is un modified to do crystal sync sound  I will do a test to see if I can record anything I film, with my zoom h4n, and or depending if I get a battery my zoom h4n and chinon boom mic. Hopefully I will be able to find a battery for the Chinon and conduct a test with it in conjunction with my Zoom H4N. I would how good those boom mics were?
I plan on using something like Audacity to perhaps remove the noise of the camera running film in w/e I record. As for the recording itself..at the moment it will probably be an interview, conducted either on the street with a lot of noise and/or in a very quiet room were the only noise will be from my interview and the noise of my camera. Do you think I will be able to strip the noise my camera makes while running film from my actual audio from my shoot?
also if anyone has a 400ft adapter I am in the market for one ;D
Edited by Rudy Velez Jr, 07 April 2013 - 05:11 PM.
#2 Rudy Velez Jr
Rudy Velez Jr
  • 225 posts
Posted 07 April 2013 - 05:12 PM
is it possible to make your own reflectors and or light bouncers?
here is a link that shows more of my set up:
http://idontspeakthatjargon.tumblr.com
Edited by Rudy Velez Jr, 07 April 2013 - 05:15 PM.
#3 Ian Cooper
Ian Cooper
  • 469 posts
  • England
Posted 08 April 2013 - 01:54 AM
You may find it beneficial to remove the microphone from the camera - bolting it to the camera means every slight vibration and noise made by the camera will go straight to the microphone.
If the camera's sat on a tripod, then just putting the microphone on the ground beneath the tripod will isolate the camera noise a lot more than having them fastened together.
Outdoors I used to be able to record sound whist filming with a K3 without picking up camera noise.  The technique was to use a boom mic positioned perhaps 15-20ft in front and offset to the side of the camera slightly - this put the camera in one of the areas where the microphone was least sensitive, general outdoor countryside ambient noise was sufficient to do the rest.
#4 Rudy Velez Jr
Rudy Velez Jr
  • 225 posts
Posted 09 April 2013 - 02:30 AM
Dear Ian,
Thanks for your insightful response. I will defiantly follow through with your advice and post my results and share them with you.
sincerely,
rudy velez jr.
Also tagged with one or more of these keywords: Canon Scoopic MS
