Totally new to super 8, need help regarding batteries
#1 jack bamber
jack bamber
  • 1 posts
Posted 13 April 2013 - 08:35 AM
As mentioned in the title I am totally new to the super 8 format and film cameras in general, only previous experience with cameras has been using various old 127 cameras found in the roof.
I looked on ebay and found a Sankyo super cme 880 hi-focus, i looked online and really liked that it had a large zoom and only needed AA batteries, for cheap and some film so was really looking forward to blasting through a first film to see the results. The camera looked in perfect condition and everything works except the battery check, its meant to show a needle on the viewfinder screen but nothing happens
So first time filming, on and off in like 10second blasts as filming some surfing and everything seems to be working fine but then the batteries, new duracell (so i assume quite good batteries), run out after only 1 hour as nothing happens when the trigger is pressed, whats going on???
The battery compartment and the conections look immaculate with no damage visable whatsoever, so im baffled?
Anybody got any ideas?
Should i look to get it repaired? If so anybody know a good repair shop in the UK?
I assume repair would cost more than the camera so any other similar super 8 cameras that people would recommend, large zoom needed???
any help appreciated
thanks
#2 Zac Fettig
Zac Fettig
  • 338 posts
  • Boston
Posted 13 April 2013 - 12:26 PM
Sounds like a short somewhere. Probably in the battery check mechanism. You could probably get it repaired, but be prepared to spend way more than you did on the camera.
The easiest approach, get rechargable AA's. They're reasonably cheap these days. Keep a second set. Only close the battery door when you're ready to shoot.
#3 Mark Dunn
Mark Dunn
  • 2797 posts
Posted 13 April 2013 - 12:36 PM
The batteries should certainly last a good number of cartridges. If you are sure it has drained the batteries, rather than developed a fault, try to measure the current drain when the camera is not running with a multimeter. It should be negligible. If it's tens or hundreds of milliamps, as Zac has said you have a fault. To flatten a set of alkalines in an hour requires a current of a couple of amps. If the camera is otherwise OK, Zac's tip about disconnecting the batteries is spot-on.
Edited by Mark Dunn, 13 April 2013 - 12:37 PM.
