Angenieux 28-340
Angenieux
#1 JT Crofts
JT Crofts
  • 2 posts
Posted 16 April 2013 - 09:45 PM
I was wondering if anyone has an opinion on the New 28-340? we own the 24-290, and was going to buy another or the 28-340. I am on the business side, and my partner is in the operation side. He is not sure if this new lens will be in demand like our 1st one. Any thoghts or comments are welcome...Thx
#2 Kar Wai Ng
Kar Wai Ng
  • 127 posts
  • Toronto, Canada
Posted 16 April 2013 - 11:14 PM
It's really just a 24-290 with a very mild teleconverter to enlarge the image circle so that it covers 5K on the Epic. Slight loss of speed from T2.8 to T3.2 which is the tradeoff. The 24-290 does cover 5K on the Epic down to about 35mm or so.
Typically the wide end of these zooms aren't used too often (go to a 17-80mm or 15-40mm lightweight instead) so in my opinion the 24-290 is not particularly at a disadvantage; it's still the workhorse zoom of choice. The 28-340 is a big investment that serves a smaller niche; that said, depending on your market and whether you think the 6K Dragon sensor will increase demand for larger image circle lenses, that may change your perspective.
Personally, 90% of my work is Alexa based which is a proper S35 sized chip, and half the jobs I work on with Epic shoot 4K anyway.
  • 2
#3 JT Crofts
JT Crofts
  • 2 posts
Posted 17 April 2013 - 10:53 AM
Thanks so much for this info...this helps us moving forward....Cheers JT
#4 Oliver Hadlow Martin
  • 102 posts
  • 2nd Assistant Camera
  • UK
Posted 17 April 2013 - 02:00 PM
Coming from a stills photography background I never really understood the use of such a lens with so many elements - the possibility for image degradation must be quite high.
On the productions I've assisted on it was largely just a thing of convenience and speed. Is this always generally the reasoning for a DP to select this in his camera package? Time is money etc?
#5 Simon Miya
Simon Miya
  • 82 posts
  • Portland, OR
Posted 17 April 2013 - 03:44 PM
Actually the Optimos have stellar image quality - the biggest drawbacks of the 24-290 are the size and 4' minimum focus, not image problems.
#6 Oliver Hadlow Martin
  • 102 posts
  • UK
Posted 18 April 2013 - 07:25 AM
When compared to a prime lens? I mean I guess so at £50k they probably should be heh. I just usually associate many element lenses with a large range in focal lengths with poor performance.
#7 Stuart Brereton
Stuart Brereton
  • 3395 posts
Posted 18 April 2013 - 05:35 PM
They perform just fine. The main drawbacks are weight and size.
