How to meter a scene as a whole
metering incident metering lighting
#1 Alejandro Gonzalez
Alejandro Gonzalez
  • 24 posts
Posted 02 May 2013 - 10:05 PM
Just wanted to know how a scene would be metered if your trying to get the correct exposure of the set - not necessarily a particular subject - but the whole shot as a whole. Say this shot for instance.
Would you walk all the way up to the empress and incident meter her since all the light will be hitting the dome? Or would you spot read?
Love this movie btw beautifully photographed.
#2 Chris Millar
Chris Millar
  • 1642 posts
Posted 02 May 2013 - 10:20 PM
Practical answers will no doubt follow - instead I'll ask you something that'll hopefully get you thinking about the ways you can figure this all out for yourself
>> How do you, and from where exactly do you define 'all the light' ?
#3 David Mullen ASC
  • 20072 posts
Posted 02 May 2013 - 10:26 PM
I'd meter the soft and the hot light coming from the side and then decide how dark or bright I wanted things to feel.
#4 aapo lettinen
aapo lettinen
  • 1137 posts
  • Finland
Posted 03 May 2013 - 07:59 AM
You can decide what object you want to render middle gray and meter the exposure from there.
I usually seek a middle gray object inside the scene and decide how much over/underexposure I want to that area (object for ex. underexposed by 2 stop when in shadow area)
I usually use following technique, especially when in uncontrollable lighting situations:
-meter the key side (T5.6)
-meter the fill side  (T1.4)
-decide how dim you want the fill side to be compared to middle gray (eg. 2 stops under = exposure T2.8)
-adjust exposure and/or lighting if your key side is too hot or your fill side does not render correctly
(I usually light by eye, and make sure the ambience level (or fill side) falls to desired stop)
#5 David Mullen ASC
  • 20072 posts
Posted 03 May 2013 - 08:32 AM
Keep in mind that this set was probably lit using a meter so that the light falling into the room was similar from front to back so it's not like you had to take dozens of meter readings around the room.  Since it's a wide shot, I'd probably just meter the light falling into the center of the room, maybe back where the Empress is sitting, and then decide how dark or hot to make the exposure.
#6 Stephen Selby
Stephen Selby
  • 79 posts
Posted 11 December 2013 - 11:15 AM
Very interesting. If you shoot digital I'd:
1 use the histogram to evaluate highlights
2 use the monitor til it looks right
3
A) For an evenly lit scene - little contrast and lots of frontal lighting the cameras meter reading is normally quite accurate.
B) For dramatic lighting such as chiaroso I find that an average weighted meter reading is best about -1 EV
C) For contre-jour spot metering works but on the whole +1EV up to +2EV is about right unless you want a silhouette
