Minimum working distance of Angenieux 10mm
#1 Owen Parker
Owen Parker
Posted 11 May 2013 - 08:07 PM
Does anyone know the minimum working distance of an Angenieux 10mm Retrofocus?
Or the min focus distance in C mount?
It's a 60 year old cine lens you could get for the Filmo so the data for the lens is hard to come by.
I've trawled the internet to no avail.
Any thoughts?
#2 Dom Jaeger
Dom Jaeger
  • 1734 posts
  • Melbourne, Australia
Posted 12 May 2013 - 06:37 AM
It depends on the stop, and whether the back-focus of the particular lens is still correctly set. Normally a fixed-focus wide angle like that has the back-focus set so that the lens focuses close to the hyperfocal distance (about 10 feet) to give the maximum depth of field. I don't have the depth of field table but wide open your minimum is probably around 5 feet, getting closer as you stop down. If the back-focus is slightly out it will shift the depth of field range either closer or further away.
It actually also depends on your circle of confusion figure, which is simply a way of determining when something could be considered 'out of focus', ie how critical focus will be when the final image is viewed. A video destined for youtube for example needs a far less critical CoC than something that will be projected on a large screen. If you come across a depth of field table for the Angenieux 10mm it will most likely use the traditional CoC figure for 16mm format of 0.0005" or 0.015mm. Check out http://www.dofmaster...matography.html
In a pinch, simply unscrewing the lens a quarter turn (or more properly shimming it out a little) will shift the minimum focus closer.
#3 Owen Parker
Owen Parker
Posted 12 May 2013 - 06:53 AM
Dom, much obliged.
Very useful link, thanks for that.
