YASHICA SOUND 50XL
15 replies to this topic
#1 Joseph Konrad
Joseph Konrad
  • 64 posts
Posted 20 May 2013 - 03:35 PM
Hello all,
I have ordered 50D and Tri-X from Kodak.  I know that technically this camera is not supposed to work with these films (http://super8man.fil.../super8_30.html) but what do you suppose would happen if I tried it anyway?  Thanks,
Joe
#2 Ian Payne
Ian Payne
  • 57 posts
Posted 20 May 2013 - 07:55 PM
The tri-x will work.
#3 David Cunningham
David Cunningham
  • 1054 posts
Posted 20 May 2013 - 08:12 PM
Looks like it will meter the 50D at 25. That's one stop over which is fine with 50D. You'll hardly notice.
#4 David Cunningham
David Cunningham
  • 1054 posts
Posted 20 May 2013 - 08:14 PM
In fact. One stop over is better than under and maybe even a good thing for grain reduction. The tri-x will meter at 250 or 1/4 under which is again perfect. You want to come in under rather than over.
#5 Joseph Konrad
Joseph Konrad
  • 64 posts
Posted 20 May 2013 - 09:34 PM
Great.  Thanks a bunch, Ian and David.  I hadn't expected too many people to be familiar with this camera.
#6 Joseph Konrad
Joseph Konrad
  • 64 posts
Posted 20 May 2013 - 10:10 PM
If I were to use 200T film, then, I assume it would be metered at 160T because I assume the camera either always meters down or picks the speed that is closest.  And that would also work because the goal is always to have the film be overqualified for what it is metered at, not underqualified.  Do I understand properly?  Thank you again for your wonderful help.
#7 Jamie Frazer Noakes
Jamie Frazer Noakes
  • 81 posts
  • The Northlands of Sweden
Posted 20 May 2013 - 11:20 PM
I think 50D will be exposed as 40 as you should remove the colour conversion filter (if it does not have the filter sensing pin with automatic removeal of the filter) and thus have the "tungsten" setting rated at 40, and as this is daylight balanced stock you will be fine.
#8 Jamie Frazer Noakes
Jamie Frazer Noakes
  • 81 posts
Posted 20 May 2013 - 11:23 PM
With Kodak negative film, overexposing it by at least one stop gives a better look. Exposing it as 160 is fine too, even though this is only a third of a stop overexposure.
I would be careful not to overexpose reversal film, it is best exposed at box speed.
#9 Bill Rodgers
Bill Rodgers
  • 135 posts
  • London & Sussex UK
Posted 21 May 2013 - 03:39 AM
I LOVE the Yashica 50XL!!!
It's a really easy to use, robust 'run-n-gun' point and shooter, ideal for handheld at 18fps.
The lens is pretty sharp and it handles Tri-X beautifully. I also really appreciate it's overall design and functionality. B)
#10 David Cunningham
David Cunningham
  • 1054 posts
Posted 21 May 2013 - 07:09 AM
I'm 99% sure that this camera will only detect 25, 100 and 160 as "daylight" speeds.  It will have the daylight/tungsten pin inside to "choose" daylight vs tungsten and set it's EE based on that.  So, I'm pretty sure it will set at 25.
I believe Tri-X is notched for tungsten.  So, leaving it set to "indoors" will keep the filter out-of-the-way and result in an EE setting of 250.  But, the speed notch MIGHT detect 100/160, in which case it will be set to 160 and very slightly over expose.  Even that little will likely clip bright highlights.
#11 Joseph Konrad
Joseph Konrad
  • 64 posts
Posted 22 May 2013 - 08:56 AM
Thanks, guys.  I'll give it a try and see what happens!
#12 Joseph Konrad
Joseph Konrad
  • 64 posts
Posted 22 May 2013 - 08:58 AM
It really is a beautiful camera.  Very hefty and well-laid out.  I picked it up for around $50 mint off of ebay.
  • 1
#13 Bill Rodgers
Bill Rodgers
  • 135 posts
Posted 22 May 2013 - 09:27 AM
$50 is a bargain for that BEAST!
  • 1
#14 Jamie Frazer Noakes
Jamie Frazer Noakes
  • 81 posts
Posted 22 May 2013 - 03:31 PM
Remember the daylight value of 25 was for Kodachrome 40 which was a tungsten balanced film that was rated at 25 in daylight with the 85a filter in place - for a daylight balanced stock it will need the 40 Tungsten setting as the 85a filter is not needed.
  • 1
#15 David Cunningham
David Cunningham
  • 1054 posts
Posted 22 May 2013 - 07:48 PM
Right. So it will technically be exposing in tungsten mode so it's exposing at 40. Good point. Got it.
So yeah. Even better. 50D should expose perfectly. Still not positive about tri-x. But. Pretty sure it will expose at 250. Again, a good safe exposure.
#16 Jamie Frazer Noakes
Jamie Frazer Noakes
  • 81 posts
Posted 10 June 2013 - 02:52 AM
I have to add that technically Velvia 50D from Wittner is notched as 50D - HOWEVER - you do need the follow the advice written on the pacakging (yes, it's in Greman) which is to manually remove the colour conversion filter so that the filter switch is at the "bulb" setting, and then you will get the 40 ASA rating.
  • 1
