Confused on Incident reading???
#1 Michael Lee
Michael Lee
  • 2 posts
Posted 22 May 2013 - 07:22 AM
This is surely a stupid question but I've read an abundance on this but am still a little confused do I need to compensate for the reading given by an incident meter off a key for a  Caucasian face?, I know I need to do this with the reflective and spot meter so as to compensate for the reflective value of the a Caucasian face. My instinct says I should as the subject still has to reflect the light back, is this correct?
#2 Stephen Murphy
Stephen Murphy
Posted 22 May 2013 - 07:53 AM
I think you'll find this tutorial beneficial
#3 David Mullen ASC
  • 20254 posts
Posted 22 May 2013 - 10:48 AM
You don't need to compensate for the caucasian face with an incident meter because the incident meter just tells you the amount of light hitting the dome so that 18% grey will be exposed correctly, so a lighter subject will render lighter and a darker subject will render darker relative to 18% grey.
A reflective meter / spot meter measures the light reflected off of a subject itself and assumes that the subject is 18% grey, so if the subject isn't, then you have to compensate to make a lighter object look lighter and a darker object look darker.
Of course, all meter readings have to be interpreted creatively to create the effect you want.
#4 Michael Lee
Michael Lee
  • 2 posts
Posted 24 May 2013 - 05:41 AM
thanks Dave that was a really helpful and clear explanation much appreciated cheers,
#5 Gregg MacPherson
Gregg MacPherson
  • 1966 posts
  • New Zealand
Posted 27 May 2013 - 06:14 PM
Is it possible to pin that near the top of the board.
Edited by Gregg MacPherson, 27 May 2013 - 06:15 PM.
