kodak 16mm unknow film
#1 Guillaume Collignon
Guillaume Collignon
  • 12 posts
  • Switzerland
Posted 25 May 2013 - 04:45 AM
Hi all,
I recently got a lot of kodak 16mm color negative films. In the lot, there was this can, without much informations on it. I just know from the seller it's color negative, and one perf. The speed is unknow, also if it's a daylight or tungsten film.
Anybody could help me to know what's inside?
thanks!
#2 Dirk DeJonghe
Dirk DeJonghe
  • 615 posts
  • Kortrijk,Belgium
Posted 25 May 2013 - 04:54 AM
50 ISO daylight stock on Polyester base, similar emulsion to 7201.
#3 Guillaume Collignon
Guillaume Collignon
  • 12 posts
  • Switzerland
Posted 25 May 2013 - 06:14 AM
thanks a lot Dirk!
#4 Jock Blakley
Jock Blakley
  • 73 posts
  • Melbourne, VIC
Posted 27 May 2013 - 08:34 AM
The trick is in the Number Code, which is the first four digits of the batch number.
2201 decodes to ESTAR (polyester) base, camera-original film, and 01 for VISION2 50D. The production version of this film on the standard acetate base would be, as Dirk notes, 7201.
Properly it should be 3201, as a 2 in the leading position is properly for 35/65/70mm ESTAR, but Kodak has been inconsistent with this in the past (I have a few cans of HAWKEYE Surveillance Film 2485 in 16mm when it should be 3485).
You will also sometimes see a 0 as the first digit for a Special Order film - ESTAR versions of VISION2 500T were sold as SO-218 and coded 0218.
It's important also to note the Specification Number (SP): 618 in this case, which refers to 16mm with 1R perf on Z-type (3-inch diameter) core in Winding A, not the standard Winding B.
#5 Dirk DeJonghe
Dirk DeJonghe
  • 615 posts
  • Kortrijk,Belgium
Posted 27 May 2013 - 08:54 AM
If you want to make it a B-Wind, you need to rewind it ONCE in the darkroom, emulsion in, to a small camera core.
#6 Brian Pritchard
Brian Pritchard
  • 332 posts
  • Rushden UK
Posted 28 May 2013 - 01:55 AM
Don't forget that the edge numbers will be around the wrong way.
Brian
