Matte Box
kransnogorsk 3 scoopic ms kinor 16mm 16mm k3 canon scoopic ms matte box
10 replies to this topic
#1 Rudy Velez Jr
Rudy Velez Jr
  • 225 posts
Posted 26 May 2013 - 03:38 PM
Can one put a matte box on: a K3, Kinor 16mm and/or Scoopic MS? Do I need to know a particular thread size.
Forgive me if this is a dumb question
Also can one load short ends that are under 400ft into a 400ft magazine, so say for example a 290ft short end into a 400ft magazine?
#2 Brian Drysdale
  • 5196 posts
Posted 26 May 2013 - 04:52 PM
You can put any length under 400ft into a magazine, although there does reach a point where it's no longer worthwhile.
  • 1
#3 Gregg MacPherson
Gregg MacPherson
  • 1932 posts
  • New Zealand
Posted 26 May 2013 - 07:06 PM
As a student we visited a rich visiting sports TV production shot on 16mm with 10 or 12 cameras, I remember the DoP flicking short ends into the air to recover the core. None of us had the nerve to ask if we could just keep the film. So it's really just a question of what's usefull, economic to load and use.
Re the matte box question.,
There are often ready made solutions to how to mount the MB for different cameras. Otherwise you can invent your own.
If the lens has a front that does not rotate as it focuses, then a solution is possible where you just clamp onto the front. Look at most of the Chrosziel 4x4 MB and you see this option. There are cheaper Chinese or Indian versions. If the lens front rotates as you focus (older zoom lenses for example) then you have to use rods. There is almost no camera or configuration that you cannot custom do with rods. The issue is how to align the lens axis with the central axis of the MB. You will sometimes just improvise. Add spacers to get the height and align the threaded camera mounting holes to get the horizontal alignment.
Some cheap Chinese MB have easy height adjustment. Maybe some have a way of horizontal adjustment also
A cheap MB may be OK if you have little money. Better to spend on the FF.
  • 1
#4 aapo lettinen
aapo lettinen
  • 1137 posts
  • Finland
Posted 27 May 2013 - 03:06 AM
yes you can use short ends under 400ft with 400ft mags.
If I remember correctly, the Russian cores are a little bit smaller than western ones (was it 1.5" versus 2" ?) , so you can't load a full 400ft roll of film to Kinor 400ft magazine if the film is on 2" core
#5 aapo lettinen
aapo lettinen
  • 1137 posts
  • Finland
Posted 27 May 2013 - 03:07 AM
because the outer diameter of the film roll is then bigger
#6 Rudy Velez Jr
Rudy Velez Jr
  • 225 posts
Posted 28 May 2013 - 09:36 PM
well i dont have a 400ft mag yet but  how would I load a 400ft roll onto the magazine if the outer diameter of the film roll is bigger?
#7 Ian Cooper
Ian Cooper
  • 469 posts
  • England
Posted 29 May 2013 - 02:42 AM
I may be missing something here, but your original question was about putting short ends that are less than 400ft in length into a 400ft magazine.  In this case it will be impossible for less than 400ft of film to be of larger diameter than the 400ft of film the magazine is designed for?
#8 Gregg MacPherson
Gregg MacPherson
  • 1932 posts
  • New Zealand
Posted 29 May 2013 - 03:43 AM
You could just beak down your 400' rolls.  Whatever's most usefull.  2x200'... or  spool off 100' to leave 300'.  Normally you do this in a darkroom,  but people often improvise.  You need a set of rewinds and one or two split spools depending on what you are doing.  I have at a pinch just held a 400' roll in my fingers as I  spooled it onto a rewind.  Not the safest way to do it.
If you are spooling off your own rolls,  you have to spool it twice.  The second time you will get the wind orientation back to what it was,  and the head,  tail relationship correct,  so that edge numbers,  bar code or whatever they do nowdays will be in the right direction.
#9 Mark Dunn
Mark Dunn
  • 2665 posts
Posted 29 May 2013 - 04:05 AM
I think the point was that a Kinor mag might not take a full load on a 2" core if the Russian cores it was designed for are smaller.
#10 Will Montgomery
Will Montgomery
  • 2069 posts
  • Dallas, TX
Posted 30 May 2013 - 05:14 PM
SR mags allow for 100' daylight spools and 400' on cores as well as anything less than 400' on standard core.
#11 Rudy Velez Jr
Rudy Velez Jr
  • 225 posts
Posted 31 May 2013 - 05:14 PM
if you google kinor 16mm and you got the kinor 16mm blog spot. Posted is a camera for sale that has a matte box that looks like it was made for the kinor 16mm
Also tagged with one or more of these keywords: kransnogorsk 3, scoopic ms, kinor 16mm, 16mm, k3, canon scoopic ms, matte box
