Wondering is there any difference in muslins from cine or fabric store?
Muslin
12 replies to this topic
#1 Paul Dombrovskis
Paul Dombrovskis
Posted 29 May 2013 - 02:52 AM
I am looking into buying the muslin for my next shoot and was wondering is there any difference in muslins that are sold from cine oriented stores and regular fabric stores. Like here
http://www.fabric.co...slin-white.aspx
And here
http://www.filmtools...12blmusec1.html
Or here and it is even hemmed at the edges
http://www.inspironp...hbbsv2de7oalbo6
Best,
Paul
#2 Mark Dunn
Mark Dunn
  • 2798 posts
Posted 29 May 2013 - 04:11 AM
The cut sheets are wider than the 9' by-the-yard so you avoid a seam shadow on the larger sizes. Other than that,  I don't think so, unless it is fireproofed. Looks like you could save a few quid.
#3 Paul Dombrovskis
Paul Dombrovskis
Posted 30 May 2013 - 03:53 AM
Thanks Mark, so I guess muslin is muslin and it doesn't affect where it has came from
#4 Mark Dunn
Mark Dunn
  • 2798 posts
Posted 30 May 2013 - 04:27 AM
It's a long time since I did it but when I needed backdrop canvas I went straight to a theatrical supplier.  It doesn't come any cheaper. That first one seems cheap enough though. It will need hemming so it doesn't tear. Have you a seamstress girlfriend (or mother, even?).
#5 Paul Dombrovskis
Paul Dombrovskis
Posted 01 June 2013 - 02:46 AM
I am more looking for using muslin as a diffusion and to reflect the light from it. Any ideas what difference is between cotton vs cotton/poly muslin and do you think I could you something like this as a diffusion and if needed reflector sometimes?
http://www.ebay.com/...=item5655b3a39d
#6 Mark Dunn
Mark Dunn
  • 2798 posts
Posted 01 June 2013 - 04:34 AM
I'd expect that to be much denser.
#7 David Mullen ASC
  • 20242 posts
Posted 01 June 2013 - 01:00 PM
And probably backed with black.
#8 Maximilian Hillmer
Maximilian Hillmer
  • 37 posts
  • Germany, California
Posted 02 June 2013 - 07:04 AM
i think they have a finer structur. That ist something that must be checked with a light meter...
#9 Mark Dunn
Mark Dunn
  • 2798 posts
Posted 02 June 2013 - 07:26 AM
Ask for a small sample.
#10 Maximilian Hillmer
Maximilian Hillmer
  • 37 posts
Posted 02 June 2013 - 03:29 PM
yes I think they give you an example so you can test the processing
#11 Dustin Supencheck
Dustin Supencheck
  • 23 posts
Posted 05 June 2013 - 01:53 PM
One of my most useful bounce sources I made was a 4x4 piece of bead board (foam from home depot) fastened to foamcore for support. Then I covered the foamcore with muslin I purchased from a fabric store. Cost less than $20.
The great thing about fabric stores is that you have so many options of quality and color in the fabrics for half the price. The film tools stuff is expensive in the same way that clothes pins are cheaper than "C-47's"
#12 JD Hartman
JD Hartman
  • 1791 posts
  • Edison, N.J. U.S.A.
Posted 07 July 2013 - 11:07 AM
You don't think companies like Avenger, Mathews or Mole contract to have spacial fabric woven just for them do you?  Muslin is muslin, the only difference in price might be the width and how tight the weave is (threads per inch).  California Sunbounce is a type of sailcloth.  Duvetyn/Commando cloth is fireproofed, most silks, muslins, bounce/diffusion fabrics, etc,. are not.
Certainly not the cheapest supplier but some interesting reading: http://www.rosebrand.com/
Sorry, I ramble a bit.
#13 David Mullen ASC
  • 20242 posts
Posted 07 July 2013 - 11:29 AM
I once used some muslin on frames that I thought were too loosely woven, I was getting a faint hard shadow from the source coming through the weave, I ended up having to put Opal behind the muslin.
