Transporting Super 8 into Single 8 carts. DIY.
10 replies to this topic
#1 Zachariah Shanahan
Zachariah Shanahan
  • 49 posts
Posted 05 June 2013 - 01:30 AM
Ok, I'd like to shoot Vision 200T on my ZC1000 and have found that there are different types of cartridges.
The newer ones are one complete piece of plastic and it looks nigh impossible to open them without damaging, but I have 2 unexposed carts from Retro8 that must be the older type that they reuse for future stock, being easier to pry open, glued back together.
I have an already opened Single 8 cart in the post, and some crappy old film that came in another Super8 camera, and will be practicing asap.
I'm wondering has anyone taken the steps to complete such a process and knows the sweet spots to carefully open and load. I know that 40ft will only fit inside and I'll have to trim 10, which I later plan to cement together to use.
Regards!
#2 Jean-Louis Seguin
Jean-Louis Seguin
  • 762 posts
  • Montreal, Canada
Posted 05 June 2013 - 07:35 AM
Try contacting Ignacio Benedeti, who is a participant to this forum.
See:
Jean-Louis
#3 Marc Marti
Marc Marti
  • 50 posts
Posted 05 June 2013 - 04:06 PM
The technique is very simple: Starting in the dark, you make a little hole at the beginning of the film (any paper perforator is ok) and engange it on the left side reel. Some people do it just with adhesive tape, but I found the perforator system cleaner...
Then, start rolling the reel till you nearly fill that side of the cartridge. Be careful no to overfill it. The film has to have a certain freedom of movement.
After that, you can take the final leader out of the cartridge, close it, and (if you want) turn the lights on. Now you make another hole at this end of the film. Close the lights again, open the cartridge and engage it at the right reel. Be sure that the film pass outside the cartridge with the emulsion out and the perforations down.You're done!
This is a picture of the way the films goes inside the cartridge: single8_systeen.jpg
Practice first with a trashy piece of film with the lights on. Don't worry if it looks complicated at first sight. It's a very easy process as soon as you get it.
If you're recharging from super-8 cartridges, it's best to film first the entire film with the super-8 camera (with the lens cap on, of course) and start recharging the single-8 from the end of it (the part with the "exposed" written on it).
  • 1
#4 Zachariah Shanahan
Zachariah Shanahan
  • 49 posts
Posted 05 June 2013 - 08:17 PM
Thank you so much!
Also I did ask Ignacio, who I have on FB, but he must be busy, no response yet.
#5 Andries Molenaar
Andries Molenaar
  • 691 posts
  • Amsterdam
Posted 06 June 2013 - 01:24 AM
Thank you so much!
That can take weeks if any response at all. He seems to switch off notifications from here and other fora.
Best find a direct email-address.
There are some instruction video's on Youtube. A number in Spanish. There is an active group in Spain, apparently. Also on man attempted to start a paid service for striping film pre-exposure and refill. It died before it sold anything.
Somebody built a refilling setup using a cheap Fuji camera and some rollers and reels. To fill from split DS8.
Edited by Andries Molenaar, 06 June 2013 - 01:25 AM.
#6 Marc Marti
Marc Marti
  • 50 posts
Posted 06 June 2013 - 05:58 AM
Yeah, I've got this very same machine and it's a blast! But the same operation is very easy to do by hand. Just slower.
Till last year, there were a very active super-8 scene in Spain, but the economical situation gave us a serious decline, specially considering that color reversal film is now freakingly expensive :unsure:
Edited by Marc Marti, 06 June 2013 - 06:00 AM.
#7 Zachariah Shanahan
Zachariah Shanahan
  • 49 posts
Posted 07 June 2013 - 08:15 PM
Seeing as Single 8 can rewind and fast forward, I should have no problem with practise, the issue that still remains is prying open the cartridge carefully...Does anyone here know the sweet spots?
#8 Geoff Howell
Geoff Howell
  • 168 posts
Posted 08 June 2013 - 06:42 AM
Here you go:
Skip to about the half way mark.
You should definitely track down some of the mk1 pre 1970's cartridges; they're so easy to open up compared to the later models.
I've managed to collect about 6 of them (mostly through ebay) that I plan on using once my supply of r25n runs out.
Also be aware that single 8s notch system is way more complicated than super 8, there are in fact 3 completely independent notch's on each cartridge; each designed to work with a different type of camera. For instance, a camera like a fujica P2 will read the notch located on the underside of the cartridge but a fujica AX100 will only read the notch on the left hand side of the cartridge.
#9 David Cunningham
David Cunningham
  • 1054 posts
Posted 08 June 2013 - 12:42 PM
Yipes, now that is dedication and a whole lot of work.  The man even built his own reloading table for this.  Really amazing when you consider you have to do it all in total darkness.
#10 Andries Molenaar
Andries Molenaar
  • 691 posts
  • Amsterdam
Posted 08 June 2013 - 02:50 PM
Not to mention wrecking EURO 30+ for the 30 meter Fomapan Ds8 to make the demonstration video.
It is very much how I do splitting and Kaccema filling.
I do the handling of the ends in the lights. Stick 10cm of film out of a slit in  a prepared can which holds the roll.
No need to overstretch one's selve :)
The only trouble is that the choice of materials has dwindled so badly.
Edited by Andries Molenaar, 08 June 2013 - 02:53 PM.
#11 Joerg Polzfusz
Joerg Polzfusz
  • 123 posts
Posted 09 June 2013 - 02:29 PM
http://www.nakanocam...tridgeandr.html
http://www.nakanocam...gle-8notch.html
