RED Dragon
RED cameras film
7 replies to this topic
#1 Dan Grove
Dan Grove
  • 7 posts
Posted 10 June 2013 - 09:43 AM
Really want this. Someday. Anyone own this?
#2 Michel Hafner
Michel Hafner
  • 300 posts
Posted 04 August 2013 - 02:30 AM
Well, now some do. The rest will get serviced from September on.
First tests are appearing.
http://www.reduser.n...-REAL-DEAL-!!!!
#3 Reuel Gomez
Reuel Gomez
  • 257 posts
Posted 10 August 2013 - 05:43 PM
Does it come with an anamorphic mode?
#4 David Mullen ASC
  • 20072 posts
Posted 10 August 2013 - 11:11 PM
It will.
#5 Reuel Gomez
Reuel Gomez
  • 257 posts
Posted 11 August 2013 - 10:10 AM
It will.
Will it cover the height of most 2x anamorphic lenses?
#6 David Mullen ASC
  • 20072 posts
Posted 11 August 2013 - 10:36 AM
Dragon sensor is 30 x 15.8mm. 4-perf 35mm anamorphic area is approx. 22 x 18mm so 2X anamorphic lenses would cover the 1.20 : 1 area of the Dragon sensor since you don't use the full width of the sensor to get a 2.40 image once unsqueezed from 1.20 : 1. But since the Dragon sensor is 15.8mm tall instead of 18mm tall you are getting a slightly tighter field of view from the lens.
  • 1
#7 David Mullen ASC
  • 20072 posts
Posted 11 August 2013 - 04:43 PM
Doing some rough math, I get about a 1.2 crop factor with 2X anamorphic lenses on the Dragon sensor if you will using a 1.20 : 1 area, so basically if you like the view of a 50mm anamorphic on a 35mm camera, you'd use a 40mm anamorphic to get something similar in view.
#8 Reuel Gomez
Reuel Gomez
  • 257 posts
Posted 12 August 2013 - 10:19 AM
Thanks for the info.
