Push/ pulling reversal film
#1 Philip Kral
Philip Kral
  • 95 posts
Posted 18 June 2013 - 11:24 PM
When you push or pull reversal film (E.g. Tri-x) can anyone tell me which developer do you perform the actual push/ pull process? For negatives it only goes through the developer once. But reversal you use the developer, then bleach then develop again. Which one do you alter the time/ temperature process? Or is it both?
#2 Richard Tuohy
Richard Tuohy
  • 482 posts
  • Daylesford, Australia
Posted 19 June 2013 - 12:27 AM
Hi Philip,
it is the first developer only that needs to be adjusted.  Indeed, in the entire reversal process, only the first developer is time critical - everything else is 'to completion'.
good luck
richard
#3 Philip Kral
Philip Kral
  • 95 posts
Posted 20 June 2013 - 12:09 PM
Thank you!
....Now I'm curious if diafine will work in a reversal process.....that would perhaps allow an additional stop or 2 without must increase in grain theoretically.
#4 Friedemann Wachsmuth
  • 122 posts
  • Hamburg, Germany
Posted 21 June 2013 - 04:51 PM
I tried it -- Diafine is too soft as first developer. Use a paper developer in lower dilution for pushing. I prefer Tetenal Dokumol in 1+6 or 1+7.
#5 Richard Hadfield
Richard Hadfield
  • 31 posts
Posted 22 June 2013 - 02:44 AM
The Dr5 Chrome lab say they can push process tri-x 2  stops.
http://www.dr5.com/b...slide/cine.html
