Tightening Ball Joint Arm for Redhead
#1 Marc Roessler
Marc Roessler
  • 264 posts
Posted 10 July 2013 - 03:36 PM
I have a Ianiro Redhead here (the light version with the fibre body). It's mounted using a clamp with a sort of multi-ball-joint arm, like on this picture: http://s.sbito.it/im.../6381375764.jpg
The trouble is that the arm seems a bit too weak to support the full weight of the lamp when the arm is not 100% vertically positioned - the first ball joint next to the clamp (most leverage = most force) gives.
Is there any trick for making those a bit tighter?
Greetings,
 Marc
#2 Stuart Brereton
Stuart Brereton
  • 3347 posts
Posted 10 July 2013 - 08:59 PM
Looks like someone has removed the original yoke from the lamps and frankensteined a french flag arm and gaffer grip to them. Thing is, those arms are only designed to support a french flag, not a lamp....
#3 Marc Roessler
Marc Roessler
  • 264 posts
Posted 12 July 2013 - 01:46 PM
I agree they look like that.. but it seems Ianiro/Quartzcolor built them like that, as I've seen this version several times.
Also see http://www.ianiro.co...y/65-70_12.htm# ("read more")
It's probably not the most ideal design.. but is there a trick for slightly tightening this thing?
#4 Edward Lawrence Conley III
  • 192 posts
  • Los Angeles CA
Posted 26 July 2013 - 11:23 AM
You could try hammering the outside piece- lightly- until it grabs the Ball inside the ball joint.
