"New" super-8 camera to market
594 replies to this topic
#1 Lasse Roedtnes
Lasse Roedtnes
  • 68 posts
  • Electrician
Posted 26 July 2013 - 05:30 AM
Hi All,
Hypnotically let’s assume the following semi-professional camera existed on the market to be put under the christmas tree this year ^_^
A newly designed Super-8 camera with widened gate made in aluminum that records sound in license free Ogg vorbis format 48 KHz @ 16bit stereo (CD quality) on a removable SD-CARD, film frame count information is also stored on the SD-CARD as a log file along with the audio to help aid cutting.
Featuring oscillating mirror shutter for the best optical path through the lens towards the film (no glass or filters in between lens and film) when the shutter is closed the image is projected towards an integrated CMOS camera which acts as a digital viewfinder.
The camera uses standard Kodak film cassettes, however the film is brought out of the cassette and into the widened gate with integrated pressure plate and pin registration, which completely freezes the film during exposure to make sure the bouncing never occurs which is a typical trademark of older super-8 cameras.
It features a build in light meter for easy operation.
The frame rate is programmable from 16fps to 54fps frames pr. second with crystal phase-locked-loop synchronization (Lip sync is fully achieved throughout an entire film).
Remote controllable via WiFi (the camera creates its own hotspot) and is compatible with Android, Iphone and Windows Phone.
Exchangeable lenses via C-Mount.
 Viewfinder through the lens (while shutter is closed) via internal camera for use with standard external monitor such as Lilliput etc. (standard NTSC / PAL vide out  format)
Phase Advance feature to increment the phase if you want to interlock the camera with a TV or florescent light for example to remove shutter bars typically seen.
The external monitor acts as both viewfinder and camera status display – it shows the following information:
  • Remaining/Elapsed: feet, frame, meter
  • Exposure control
  • Audio VU monitor
  • System parameters
The camera is firmware upgradable via USB.
It has a mono XLR microphone input with true 48V phantom power and a normal stereo jack 3.5mm line-in and also 3.5mm jack mono microphone-input, there’s also headphone output (3.5mm jack) for monitoring the sound.
Microphone gain and headphone volume is adjustable.
Now to the big question what are you willing to pay?
  • 1
#2 Bill Rodgers
Bill Rodgers
  • 135 posts
  • London & Sussex UK
Posted 26 July 2013 - 06:14 AM
Hypothetically rather than hypnotically I hope? :P
I often shoot side-by-side using a simple rig with a blimped Canon 1014XL-S and a Canon HV30 HDV camcorder.
In fact I have found it is even better to use a smaller 514XL-S as both cameras are of similar dimensions and have 43mm lenses that I can attach identical C-8 wides to.
So my set-up would cost less than 500 US Dollars to recreate via eBay right now and kind of does everything I need it to of a video-assist or integrated system; I can even align the field of view.
I can well imagine that the hypothetical camera you describe would easily cost in excess of 2,000 US Dollars.
So it's not a very cost effective solution, when you can just shoot both HD and Super 8 side-by-side. :rolleyes:
#3 Lasse Roedtnes
Lasse Roedtnes
  • 68 posts
  • Electrician
Posted 26 July 2013 - 06:27 AM
Hi Bill
I guess my auto correction dictionary caught me in a bad moment it should have been hypothetically as you've already guessed.
By the way, if the hypothetical camera existed it would have these dimensions 185cm x 90cm x 110cm not including the lens or back mounted battery ;)
Hopefully this small size would hypnotize you into buying it if it became available :D
  • 1
#4 David Nethery
David Nethery
  • 56 posts
Posted 26 July 2013 - 07:15 AM
Well ,  hypothetically  I'd be willing to pay what it takes to bring such a camera to the market .       Although I would tend to think that such a camera would be more naturally suited for RENTAL through a professional camera house , at about the same rates one would expect to rent a similar 16mm camera.
If we are talking about a real project here (not just a hypothetical project)  you mentioned : "frame rate is programmable from 16fps to 54fps frames pr. second"    but while you're at it I would suggest expanding that range from 12fps  to  80fps .     80fps gets over 3x slow-motion  which would be especially appreciated . (I always liked this feature on the Beaulieu 4008 ).    If you could increase it to 4x  at 96fps  all the better  (meaning that it's continuously programmable through that entire range , so slow motion could be a "mild" boost to 36fps ,  then up to  2x at 48fps ,  54fps ,  3x at 72fps ,  80fps ,  or  4x at 96fps ).      But honestly if you produced such a camera with frame rate programmable from 16 fps  to 54fps  that would be amazing and the top speed of 54fps would not keep me from considering the camera.      I'm just saying as long as we're dreaming about such a camera why not say it could do slow-motion up to 80 or 96fps ?
"The camera uses standard Kodak film cassettes, however the film is brought out of the cassette and into the widened gate with integrated pressure plate and pin registration"
Would you consider an optional 200 ft. magazine version , similar to the Wilcam W-1   http://www.super8dat...m/wilcam_w1.htm
#5 Bill Rodgers
Bill Rodgers
  • 135 posts
Posted 26 July 2013 - 09:14 AM
Yeah, single frame to 96fps would be great but in all honesty this hypothetical camera would probably have to be around $1,000 or less to spark my own interest. :)
#6 Bill Rodgers
Bill Rodgers
  • 135 posts
Posted 26 July 2013 - 09:18 AM
I'm assuming this is actually mm rather than cm too? ;)
#7 Matt Stevens
Matt Stevens
  • 705 posts
Posted 26 July 2013 - 10:11 AM
These threads pop up every few months. it's a pipe dream. It aint happening, no matter how hard we dream.
  • 1
#8 David Nethery
David Nethery
  • 56 posts
Posted 27 July 2013 - 01:52 PM
Yes, only a pipe dream.   (and how many pipe smokers do you see these days  ?   About as many as the people who still shoot Super 8mm film I would expect) .
But the pipe dreaming is kind of fun  ...  besides the 200 ft. magazine option (like the Wilcam W-1)  the other thing I'd want to see in any new camera is a true pin registered pressure plate  drive system (which Lasse Roedtnes  mentions as part of his hypothetical dream camera)  like the very rare Mekel VIC SP-1 Cine-8   :
http://www.super8dat...vic/vic_sp1.htm
#9 Zachariah Shanahan
Zachariah Shanahan
  • 49 posts
Posted 27 July 2013 - 07:54 PM
I'd pay the same price as the current Blackmagic Pocket Cinema Camera...under $1000. If you produce this camera on Kickstarter....it might have a chance, and I would pledge. It sounds like a great idea. Make it with a focus on Vision 3 so it can produce the best images possible at 500T etc.
#10 Matt Stevens
Matt Stevens
  • 705 posts
Posted 28 July 2013 - 09:38 AM
Agreed, though with so many Kickstarters now failing to produce an end resulting product, the though of losing a gran doesn't please me. I know plenty of people who ponied up money for something andin the end got nothing.
#11 Zachariah Shanahan
Zachariah Shanahan
  • 49 posts
Posted 28 July 2013 - 07:18 PM
Yes, the Digital Bolex, for example. Currently still vapourware. It's a risk.
Will this be Max 8/Super Duper 8?
I'd be more inclined if so!
#12 David Nethery
David Nethery
  • 56 posts
Posted 28 July 2013 - 08:17 PM
Looks to me like the Digital Bolex project is coming along nicely .  I don't think it's going to just be "vapourware".
http://www.digitalbo.../getting_ready/
http://www.digitalbolex.com/alive/
If someone credible puts up a Kickstarter to develop a New SUPER 8mm camera I'd be willing to throw some support their way.    Digital Bolex is a good example of what can be done.
http://www.kickstart...e-digital-cinem
#13 Zachariah Shanahan
Zachariah Shanahan
  • 49 posts
Posted 29 July 2013 - 12:22 AM
The d16 is FAR from ready, it's been coming along nicely for 12 months, as I've been following...though I'd choose it over a BMCC for a variety of reasons, there is no RAW footage for the desired image, as the desired image has not been engineered by the sensor yet. Still Vaporware, stills are stills, not video, or the filmlike motion they are aiming for...
Anyway, I would support a team with it's head on it's shoulders to produce such a camera, but I'd want a completed test one already made with a short film on high quality stock PRIOR to doing so.
#14 Heikki Repo
Heikki Repo
  • 423 posts
  • Finland
Posted 29 July 2013 - 03:47 AM
Yeah, I'd support this on KS as well. Correctly marketed it could appeal to the 'hip' crowd as well, there are lots of people shooting 35mm stills lomography style. A camera which combines the modern (lcd viewfinder) with retro (super-8) could be the thing.
#15 Matt Stevens
Matt Stevens
  • 705 posts
Posted 29 July 2013 - 06:15 PM
Yes unfortunately it is a dream that has not yet come true. My partners and I had hoped the Digital Bolex would hit by late summer and be thoroughly tested by the Fall so that we could consider it for a low budget feature we are lining up for early 2014, but at this point we have given up on it and will likely shoot it with a 5DMKIII via RAW or possibly a RED EPIC. We really have no choice. The BlackMagic just won't ship and early work on the 4K camera is the lower dynamic range is such that the first camera actually produces a more film like image.
#16 Lasse Roedtnes
Lasse Roedtnes
  • 68 posts
  • Electrician
Posted 30 July 2013 - 02:05 PM
Hi Matt,
I know there's been alot of other posts on this forum about people wanting to produce a new super-8 camera - and it just goes to show that's alot of interest but in order to actually make one is a completely different and extremely difficult/expensive ball game - I know all about this - however never loose faith, think what would have happened if NASA had that attitude when they talked about going to the moon "just another pipe dream - aint going to happen" :P   - sometimes all it takes is someone to be proven wrong and perhaps that could be you :)
Zachariah:
This is "not just, yet, another digital camera" like the Blackmagic this is true film camera with digital viewfinder so it cannot really be compared - the cost of this type of camera is substancially higher because of all the mechanics which goes into it.
And yes it does have a "Super Duper-8 / Max-8 widened gate ;)
David:
This camera does infact have a true pin registered pressure plate which mechanically interlocks the film during each frame exposure - the pressure plate in the film casette is not used, just like the Merkel camera you have shown a picture of.
Regarding the 200ft film option this is not possible as the camera is designed for the standard kodak casette only so all the mechanics including the camera casing would have to be altered which would not only delay it further but also cost a fortune.
When talking about frame rates the hardware phase locked loop (electronics) can pretty much support anything from 1fps to 500fps with a precision better than 0.1 fps increments - the motor and batteries on the otherhand cannot - I've done lab tests running it at about 80fps to stress test the mechanics this is doable however it's only possible by driving the motor above its specified maximum voltage so from a warranty risk assesment perspective this would be "no go" - we could consider doing special firmwares which did allow this but with a reduced warrenty or alternate motor configuration.
By the way what are the typical rates for camera rental?
Heikki:
Terve!, unfortunatly kickstarter is not an option for non US, GB citizens so it would have to be Indiegogo or similar if it came to that.
I'm still hoping more people would add feedback as to the feature set, price point and wanted features - especially firmware features.
Take care
/Lasse
#17 David Nethery
David Nethery
  • 56 posts
Posted 30 July 2013 - 02:55 PM
David:
All the features you list in your first post would be on my List .   First on my list would be the pin-registered pressure plate .  Second would be the ability to use standard C-mount primes and zooms.   If it were "self-blimped" (QUIET) that would be a big plus.
The lack of a 200 ft. magazine would not concern me .  I just thought I'd throw that up there as a possiblity since you were asking .
Similarly, the upper limit of 54fps for the slow-motion would be fine.   I just thought I'd ask if 80fps or 96fps would be possible .  I understand the issues with over-taxing the motor and battery supply at the higher frame rates .   (even with my old Nikon R8 I'd only use the 54fps in short bursts, usually not more than 15 or 20 ft.    Never tried shooting a whole cartridge at 54fps continuously.     If I recall correctly the Nikon manual warned against running it in 54fps mode continuously for an extended time.)    Would a compromise of 60fps be feasible ?  (scanned and interpolated to 2x at 120 fps that would be 5x 24fps slow-motion !  Although I'm not sure if the interpolation would affect the sharpness of the slow-motion footage too much ?)
On the low-end of the frame rate I'd prefer 12fps  to 16fps, if possible.
So , in your response you refer to running stress tests at 80fps , so am I right to think you have a working prototype already made ?
I'd definitely be interested in supporting a crowd-sourcing effort (Indie GoGo or whatever) for something like this.   Good luck to you in this effort !
#18 Heikki Repo
Heikki Repo
  • 423 posts
  • Finland
Posted 30 July 2013 - 03:24 PM
Terve Lasse!
Here in Finland the list prices for 16mm and super-8 film camera rentals are following (EUR, price / day, price / week, VAT 24% + insurance 5% is added to these):
Arriflex 416 275/1100
Arriflex 16 SR3 250/1000
Arriflex 16 SR3 Adv 200/800
Arriflex 16 SR2 150/600
Aaton A-Minima 130/520
Super-8: Canon 814 XL-S 45/180
For comparison, both Arri Alexa and Red Epic-X are 900/3600 and Red Scarlet-X is 600/2400
#19 David Cunningham
David Cunningham
  • 1054 posts
Posted 30 July 2013 - 04:30 PM
So I guess the question in all this is do you have a prototype you are testing?  How much do you think it is going to cost to produce?
#20 Zachariah Shanahan
Zachariah Shanahan
  • 49 posts
Posted 30 July 2013 - 10:23 PM
Yeah, let's get straight to the numbers game. I'm all ears.
