Best Way To Convert 30p to 24p?
#1 Carl King
Carl King
  • 37 posts
Posted 28 July 2013 - 09:39 PM
Hi, I shot a documentary on Sony EX3 in 30p and am curious -- is there a reliable way to convert it to 24p? As of right now when I export to 24p I can see it skipping frames, which is very apparent during slow pans and zooms. What process / software could I use, if any? Thanks!
#2 Christoph Helms
Christoph Helms
  • 14 posts
Posted 30 July 2013 - 03:31 PM
maybe this can help:
http://philipbloom.n...rom-30p-to-24p/
#3 Phil Connolly
Phil Connolly
  • 472 posts
Posted 31 July 2013 - 01:30 PM
Doing this in your edit package is going to result in less the ideal results.
Ideally you want to use something that will do a motion compensated conversion - that can tween between frames and make a smooth result.
Either Twixtor, a Snell and Willcox or Teranex converter would give you the best results. It might be a idea to get a post house to do the final conversion rather then buy the kit yourself - since the really high end converters can get pricy.
