Looking for company who makes Motion Picture Perfs on Still Stock
perofrations perfs film lab
#1 Adiva J Koenigsberg
Adiva J Koenigsberg
  • 4 posts
Posted 30 July 2013 - 12:54 AM
Hello,
I am wondering if anyone knows of a company that can make motion picture perfs on a still stock that I am using to shoot a motion picture film as well as add a key code. I a shooting on a stock that is made for a still camera and the company cuts us rolls of 400 feet. However there is no key code and the perfs are slightly different causing instability.
So far I have found one company called Wittner-kinotechnik who provide such a service but there turnaround time is 4 months. I am looking for a company with a shorter turn around time.
Thank You,
Adiva Koenigsberg
  • 20103 posts
Posted 30 July 2013 - 01:02 AM
I thought some Arri and Aaton cameras could burn-in code (ARRICODE / AATONCODE... basically time code but would work for negative cutting I assume, or a D.I. conform)?  Are you buying unperforated stock?  Otherwise how can you put new perfs on a stock that already has them?
#3 Adrian Sierkowski
  • 7406 posts
Posted 30 July 2013 - 01:07 AM
If you have an option between Aaton code and ArriCode I hear Aaton is more often used, but consult with your post house for what they can handle and your rental house for what they can provide.
#4 Dirk DeJonghe
Dirk DeJonghe
  • 612 posts
  • Kortrijk,Belgium
Posted 30 July 2013 - 11:13 AM
A big difference between Aatoncode and Arricode is that only Aatoncode carries man-readable timecode numbers in addition to the bar codes. In a pinch the man-readable numbers might be used by a negative cutter but they are not really designed for this.
