Simulating light from a television screen
lighting television simulate
#1 Daniel Atherton
Daniel Atherton
  • 4 posts
Posted 08 August 2013 - 04:54 PM
I've got a scene to light where the script suggests the key light for the action is coming from a television screen. Characters will also be 'flicking' through the channels.
I'm sure there are lots of cool tricks and methods to simulate this. What have people had success with? What should be avoided?
Cheers
Dan
  • 20239 posts
Posted 08 August 2013 - 05:47 PM
What should be avoided is lots of flickering, unless you are going for that "Poltergeist" vibe (though today you don't even get static over a broadcast channel...)
The light from a TV has some random flashes, changes in exposure (and color, to a less degree) as edits happen in the program, and slight shifts as bright objects move across the screen.  And generally you go for a cool bias to the light because TV sets are daylight-balanced in a usually tungsten-lit night interior, though if you are going to be cutting a lot to the image on the TV set and it is color-corrected for normal balance, then the light coming off of the set can't be too blue-ish.
I find that the best method is to shine a soft light at the actors and randomly wave my hands & arms or a thin flag in front of the soft source -- that way I can speed up or slow down the flashes and shifts randomly, though it takes someone who has a good sense for this if you aren't doing it yourself.  Sometimes if I can sit below the soft light I can wave both hands and arms like someone waving flags at a ship, although the downside to this is that an actor will find it distracting -- I had one actor burst out laughing watching my hand waving.
In that case, I'm more likely to get behind the diffusion frame to be partially hidden, or to use two lights through one diffusion frame, one flicker boxes with different tempos, one barely changing, the other changing faster, both random.  Or one light on a flicker box but the other on a dimmer, just fading slightly up & down randomly.
But I think the hand or flag waving looks more natural because if you slide the flag from side to side, the soft light shifts from side to side as if something was moving on screen.  A combination of all of these tricks can work.
The other option with the new high-sensitivity cameras is to use a big TV with bright scenes playing on it, with lots of edits in the material, and use the actual light of the screen, or get a bright video projector and project the image onto the actors, softened by a light diffusion frame, maybe also thrown out of focus.  Again, you'll want to select images that are bright with lots of cuts, like a daytime action scene in a movie.
  • 2
#3 Derek Griffin
Derek Griffin
  • 1 posts
Posted 13 August 2013 - 07:18 AM
I agree with David, especially re the colour temp. If you watch from the street at night you'll see a predominantly blue glow through some windows! So keep the light source "cool" and not too much harsh flickering. I recently use an led panel with diff, internittently dimmed it up or down a fraction, and occasionally held some half CTO gel in front -- but take care the gel doesn't rattle.
  • 1
#4 Stephen Selby
Stephen Selby
  • 79 posts
Posted 11 December 2013 - 11:27 AM
I would just use a real tv or projector and shoot at a high ASA.
#5 Adrian Sierkowski
  • 7485 posts
Posted 11 December 2013 - 11:36 AM
My old trick was 1 light with 216 on it and 1 light with 1/2 CTB and something like Opal on it. Keep the 216 light constant and under, and then flicker the Opal/ctb one. It's not really a  flicker-- rather more a fading up and down a bit.
#6 Brian Drysdale
  • 5282 posts
Posted 11 December 2013 - 11:38 AM
A high ASA or ISO has the down side of increased grain or noise, it's not a complex lighting effect to do.
