Int bedroom at dusk
#1 John Milich
John Milich
  • 23 posts
Posted 14 August 2013 - 07:18 AM
Hello everyone. Ive been browsing this site for a while. Amazing information.
Anyway, I've a question regarding a scene that takes place at dusk. Its a bedroom set with one window. This is a controlled environment. We need to recreate a dusk light source coming through the window, while the room is lit with tungsten practicals and a china ball to mimic a ceiling light. I have two questions.
1. As for white balance, is it best to balance for the interior tungsten?
2. How would you best recommend I create the sunset style light through the window? There will be a sheer drape on the window and some staged branches just outside of it.
Again, this is a small set in a warehouse. Totally controlled
#2 Darrell Ayer
Darrell Ayer
  • 101 posts
Posted 14 August 2013 - 11:40 AM
If this all tungsten light I would WB for that.  Then your interior light will be white and if you want a warm light to come in you  can gel it to warm it up and see what simulates sunset lighting to your taste.  YOu can also put the light a little lower depending on what floor your story takes place on.  If you need longer shadows pull the light back.
Good luck.
