Hand Cranked Camera
#1 John Rizzo
John Rizzo
  • 58 posts
  • New York N.Y.
Posted 14 August 2013 - 04:29 PM
A client has asked me if it is possible to rent a hand crank camera in 35mm or 16mm does any one know if that is possible?
#2 Dom Jaeger
Dom Jaeger
  • 1725 posts
  • Melbourne, Australia
Posted 14 August 2013 - 10:25 PM
I'm not familiar with the rental options in your neck of the woods, but there are plenty of cameras that can be hand-cranked or modified for it.
Old Mitchells like the NC or GC have both 1:1 and 8:1 shafts for hand-cranking which you might still find in working order (we have an NC with a hand-crank, only goes out as a prop these days, but still works fine.) Eyemos can be easily set up for hand-cranking, plus many older studio cameras like Bell & Howell 2709s or Debrie Parvos. They were so well built many of them still function, but finding them might be tricky.
Arri 2Cs and 35-3s can be modified for hand-cranking, which certain rental houses may still carry. (I believe Clairmont have a hand-crank 2C as well as some hand-cranked 16SRs.) You can also use a 435 with an Arri hand-crank accessory:
http://www.arri.com/...crank_hc_1.html
With 16mm you could easily set up a Bolex for hand-cranking (although it helps to have a longer crank handle made rather than use the tiny Bolex rewind one), or any number of other old wind-up cameras - Cine-Kodak Specials, Filmos, Pathe Webos, etc. For a higher end option some SRs have been modified (as mentioned, try Clairmont).
Most hand-crank gears use an 8:1 ratio, so achieving the old silent frame rate of 16 fps is easy enough with 2 turns per second, but getting up to 24 fps is pretty hard work!
Edited by Dom Jaeger, 14 August 2013 - 10:26 PM.
#3 Gregg MacPherson
Gregg MacPherson
  • 1932 posts
  • New Zealand
Posted 14 August 2013 - 11:18 PM
What sort of frame rates are required?  If you are looking for low frame rates with beautiful smeared images could you just glue a crank to the inching knob of an arri 2 and try it?  I had,  still have,  a Cinefelx 35,  an American,  almost copy of an Arri II from WWII when copright was not an issue.   The side mount for the motor allows a crank possibility.  My pet  bucket list project involves dragging this camera on weells,  like a Buzzy Bee toy, with the wheels driving the camera movement
#4 Simon Wyss
Simon Wyss
  • 1491 posts
  • Basel, Switzerland
Posted 15 August 2013 - 12:57 AM
Why should it not be possible anymore to do what the pioneers did?
http://www.ebay.com/...=item1c35991fc9
#5 Dom Jaeger
Dom Jaeger
  • 1725 posts
Posted 15 August 2013 - 02:42 AM
It is possible, and people are doing it!
Apart from some high profile examples like Tony Scott's "Man on Fire" and "Domino" (where they used a modified Arri 2C) there are quite a few indy projects that have used hand-cranked cameras.
Some links:
http://motion.kodak....fooFighters.pdf
http://www.bfi.org.u...s/joys-analogue
http://provideocoali...and_the_canyon/
That last one is from Pro Video Coalition's Adam Wilt, documenting a shoot utilising a Bell & Howell 2709, including lots of great photos of the camera set-up.
This interview with Tony Scott and Dan Mindel after the release of "Domino" goes into some interesting detail about their hand-cranking exploits:
http://www.creativep...ots-domino/6737
There are even cinematographers like John Adderley who have made a speciality of shooting on old wooden hand-crank cameras:
http://www.adderley.net/
Old timey filmmaking is alive and well!
#6 Philip Kral
Philip Kral
  • 90 posts
Posted 18 August 2013 - 09:45 AM
The Russian Konvas cameras have a hand crank adapter, I've seen the footage from one floating around vimeo.
#7 Aaron Martin @ OH
Aaron Martin @ OH
  • 31 posts
  • Detroit
Posted 10 September 2013 - 07:31 PM
John -
You could easily purchase a DeVry camera for less than the cost of a rental. There are several for sale on eBay right now.
Aaron
