Tripod Mount Hole Size
#1 David Cunningham
David Cunningham
  • 1054 posts
Posted 29 August 2013 - 10:35 AM
Sorry to ask a dumb question...
I believe my Eclair ACL has a 3/8 tripod mount hole.  Is that true?
If so, I have a 1/4 tripod right now.  Anyone have experience with these 1/4 adapters?  (You screw them into the 3/8 hole to give you a 3/8 hole.)
http://www.bhphotovi...rew_3_8_16.html
or
http://www.bhphotovi...3_8_to_1_4.html
Thanks!
#2 John Salim
John Salim
  • 190 posts
  • Essex, UK
Posted 29 August 2013 - 11:07 AM
Yes, these adapters do work very well ....with much lighter 'stills' cameras - but don't know if I'd trust one with a much heavier 16mm Eclair.
If you must buy one, go for the ( more expensive ) Arca-Swiss adapter. This is probably made of better quality hardened steel ( as you'd expect from Arca-Swiss ), though personally I'd ask them first !
I have had one of the cheaper ones break on me, due to ( my excessive ) force. :o
One other important thing, check the Eclair's base will safely take the 8mm depth required without causing internal damage.
John S :rolleyes:
#3 Gregg MacPherson
Gregg MacPherson
  • 1932 posts
  • New Zealand
Posted 29 August 2013 - 08:08 PM
... I have a 1/4 tripod right now.
David,
What tripod head do you have there?
#4 David Cunningham
David Cunningham
  • 1054 posts
Posted 30 August 2013 - 09:32 AM
I have this tripod and only the head and plate that came with it.
Dave
#5 Mark Dunn
Mark Dunn
  • 2665 posts
Posted 30 August 2013 - 10:50 AM
I'm not sure I'd trust one of these with anything heavier than a K3 (mine has one).
You may be able to get a plate with a 3/8 fitting made up for not too much money.
#6 Glenn Brady
Glenn Brady
  • 328 posts
Posted 30 August 2013 - 11:24 AM
Screws on some tripod heads are interchangeable between 1/4-20 and 3/8-16.
