On Screen Projector Light Effect
Projector Light
#1 Jonny Franklin
Jonny Franklin
Posted 10 September 2013 - 06:40 AM
Hi All,
I am currently looking into producing a video that needs a projector be on seen on screen, when I say projector, I mean the effect of the light flickering from the projector, and not the actual projection itself. Similar to this video:
My question is that when this effect is done, are real projectors used with a high wattage bulb, or is it a lighting effect, has anyone had any experience with this type of effect? If so how did you go about it?
I imagine if it is not a real projector then maybe a hard source with a moving gobo?
Any help would be appreciated
Regards
Jonny
#2 Adrian Sierkowski
  • 7488 posts
Posted 10 September 2013 - 10:03 AM
Easiest way is real projector with a high wattage bulb and a bit of smoke in the air. especially if you want to "see" the image in the smoke.
If you just want a light you can use a lot of theatrical lights which accept lenses (like a leko) on a flicker box.
#3 Phil Rhodes
  • 12302 posts
Posted 10 September 2013 - 01:30 PM
You can of course use a video projector. Consider using an LCD or LCOS type (called D-ILA by JVC, SXRD by Sony, etc) as they will have less tendency to flicker.
#4 Jonny Franklin
Jonny Franklin
Posted 10 September 2013 - 02:14 PM
Hey Adrian,
Yes I did think about using a Leko or something similar, and using a moving Gobo with mixed colours to try and replicate a projection lamp, but was unsure if this would look too repetitive and fake? I might test a few different options including a real projector with a high watt lamp to see how they work on camera.
Hi Phil,
Thanks for the response, I did think about a video projector but did not know if the projection would be powerful enough once all of the on set lamps had been turned on. Have you used a LCD or LCOS projector yourself before when filming? If so how did it compare to the lamps lighting your subject?
#5 Chanon Wangtrirat
Chanon Wangtrirat
  • 35 posts
  • Bangkok
Posted 28 October 2013 - 04:42 PM
Yes, It's real projector in cinema. Because normal conditions in theatres are Low contamination of dust so the stream of light is hard to see.
This is achieve by using high-wattage projector which normally used in Cinema and use some hazer to make it more visible.
