Overhead Camera Angle Rigging on Location
Camera Rigging Grip
9 replies to this topic
#1 Jordan Raabe
Jordan Raabe
  • 6 posts
Posted 13 September 2013 - 07:23 PM
Can anyone suggest affordable solutions to achieve a direct overhead angle in a room on location?  Our ceilings are only about 9 ft high, but we're looking to get several high, down-angle wides.  We're on a 100mm Ball head tripod head, but can rent the necessary equipment to get the job done.
Here is an example of what we're looking for:
http://www.dvdtimes....e/abovebart.jpg
Thanks for your help!
#2 JD Hartman
JD Hartman
  • 1791 posts
  • Edison, N.J. U.S.A.
Posted 13 September 2013 - 07:45 PM
Low hat and head clamped to top of stepladder.  Two step ladders, two lengths of speedrail between them, camera mounted to right angle cheese plate, cheese plate underhung from speedrail.
#3 Kurtis Myers
Kurtis Myers
  • 8 posts
  • Grip
Posted 13 October 2013 - 02:58 PM
Swap those step ladders for something designed to hold speed rail, like clamps and sturdy stands.
#4 Rob Vogt
Rob Vogt
  • 437 posts
Posted 02 November 2013 - 03:02 PM
Use a tilt wedge.
Or if you're shooting on a go pro just use a suction cup. ;)
#5 Phil Rhodes
  • 12302 posts
Posted 02 November 2013 - 03:52 PM
First-surface mirror, then you can mount the camera horizontally? Might need a flip or flop as required, but that's trivial.
#6 Gregg MacPherson
Gregg MacPherson
  • 1966 posts
  • New Zealand
Posted 02 November 2013 - 06:15 PM
Can anyone suggest affordable solutions to achieve a direct overhead angle in a room on location?  ......
Is there a reason why you don't immediately think of a jib arm?  If you don't need much reach then the arm doesn't need to be very big.  I used to own a crappy old arm on a rough pedestal with a 1.5m reach that was pefect for setting up these shots.  An arm is a nicer way to quickly fine tune your compositions.  With a short reach there is a good chance you can directly operate the camera and arm,  introducing some potentially subtle and organic movement.
#7 Mark Kenfield
Mark Kenfield
  • 1201 posts
Posted 04 November 2013 - 08:46 PM
Yeah, I just pull out the jib and whack a wide-angle lens on for these sorts of shots. Also allows you to very easily do a gentle 'push in' towards the subject, and the setup time is only 5 minutes.
Edited by Mark Kenfield, 04 November 2013 - 08:47 PM.
#8 John David Miller
John David Miller
  • 127 posts
  • Grip
Posted 26 November 2013 - 12:14 PM
Build a goal post with pipe and put a ball leveler on it, or a cheese plate with a dovetail. If they get a periscope you can get even closer to the ceiling.
#9 John David Miller
John David Miller
  • 127 posts
  • Grip
Posted 26 November 2013 - 12:16 PM
And remember to safety off that camera!! I've seen them fall...
#10 Sanjay Sami
Sanjay Sami
  • 258 posts
  • Grip
  • Anywhere they pay me to go
Posted 13 December 2013 - 11:43 PM
GF-Jib or equivalent ... its the right tool for the job and as Gregg MacPherson says - you can very quickly adjust position and height. As you say you have several shots to get through, this would certainly be my choice.
