Using glass filters while shooting chromakey/color reflections
vfx chromakey color cast.
#1 Roma Grushevoy
Roma Grushevoy
  • 2 posts
Posted 22 September 2013 - 04:23 AM
Hello everyone!
I'm planning to do my first chromakey shooting, and, essentially, I've got couple of questions
1. Do I need to use any of glass filters to enhance the incoming quality of image ( I mean like polarising filters, when shooting outside )
2. I suggest that after litting the chroma, I might get green reflections on all objects within a frame - is this suggestion correct ? If yes - then my first question, but a bit refrased - how can I cut all the unwanted color shifts and casts ?
Main object's color is going to be medium gray/black,
Edited by Roma Grushevoy, 22 September 2013 - 04:24 AM.
  • 20254 posts
Posted 22 September 2013 - 11:14 AM
The larger and further back you can get the green screen (no larger than necessary to fill the frame of course), the less it will bounce back green light on the subject.
#3 Roma Grushevoy
Roma Grushevoy
  • 2 posts
Posted 22 September 2013 - 04:47 PM
Thanks a lot
#4 aapo lettinen
aapo lettinen
  • 1168 posts
  • Finland
Posted 23 September 2013 - 08:23 AM
you can control the green reflections with negative fill and/or bouncing white light to the shadows, if the object's surface is not too shiny. The shadow areas and hair are usually the biggest problem with green screen, along with the reflections.
I usually try to reduce reflections from shiny surfaces (tables, etc) , when camera is not moving much, by placing flags behind the object in critical areas, leaving just a necessary area of green around the edges of the object in places where the reflections are otherwise worst. Then, the object reflects the black surface of the flags (or any other surface: bounceboard, etc.) and does not need extensive work in keying...
