Arri 2C High Speed
arri arriflex 2c 35mm film
#1 Dylan Lewis
Dylan Lewis
  • 4 posts
Posted 22 September 2013 - 07:18 PM
Hello!
This is my first post here on the forum and I would like to begin it by thanking everyone who posts on here; this forum has been a huge source of information for me, basically like the film school I couldn't afford, so yeah thanks everyone.
I just recently acquired an Arri 2c, one that was advertised by the seller as a high speed model. It has the tachometer that reads up to 80fps, but from doing research on this forum and others, I understand that it is possible to attach that tach to a non high speed model. I've read that the only fool-proof way of determining if the camera is an actual high speed model is by the presence of four extra screws on the film gate that can adjust the pressure of the gate. But having been unable to find another picture of an Arri 2c gate to compare mine too, I'm unsure if the screws on my gate are the high speed ones or just the standard. Here's a pic of the gate on my 2c:
Is this the high speed gate? And if so, is the combination of the gate and the 80fps tach enough to pretty much guarantee this is definitely a high speed model and is safe to run at 80fps? Just want to be sure, as I have a high speed motor on the way and would like to be sure of what I'm dealing with.
Speaking of the high speed motor, I've read that it needs 32v to run at 80fps. At the risk of sounding silly, how exactly do I acquire 32v of power? I can't seem to find any 32v batteries that can connect to the high speed motor. (The cable for my motor has a 4 pin XLR). Is it a case where I would need to have a battery specially fashioned? Anyone who has any experience running a 2c at high frame rates, your help would be greatly appreciated! Thanks!
#2 Dom Jaeger
Dom Jaeger
  • 1728 posts
  • Melbourne, Australia
Posted 23 September 2013 - 12:13 AM
I'm not really familiar with the high speed models, but we have a high speed medical 2C in our museum (designed to shoot x-ray film) with an 80fps tacho and the pressure plate is the same as yours. Only one other 2C we have has the same pressure plate (but the tacho is standard 50 fps max), all the other standard speed 2Bs and 2Cs we have don't have the 4 nuts on the back of the pressure plate. So I would assume that yours is a high speed plate.
Aside from possibly giving the camera a fresh lube, I don't think you need to worry about anything else. The mags should be OK, 435 literature says you can use older magazines up to 130 fps, well past what your 2C can do. Test with some old stock, if there are issues it might be worth having the mag take-up and feed tensions checked.
You can build a 32V battery by joining four 8V lead acid batteries in series. Something like this:
http://www.allbatter...y/8v/3-5ah.html
joined negative to positive.
#3 Mark Dunn
Mark Dunn
  • 2665 posts
Posted 23 September 2013 - 01:46 AM
A mains transformer might be the only sure way of getting full speed.
I recall that the Locam 16mm. medium-speed would only ever reach 400fps instead of the rated 500 on battery.
Edited by Mark Dunn, 23 September 2013 - 01:47 AM.
#4 Dylan Lewis
Dylan Lewis
  • 4 posts
Posted 24 September 2013 - 03:42 PM
Thanks very much for your replies!
#5 Tim Carroll
Tim Carroll
  • 2168 posts
  • Chicago, Illinois
Posted 08 October 2013 - 02:56 PM
Just like sticking an 80 fps tachometer in a standard Arri 2C, you can also stick a high speed gate in a standard 2C.  The pressure plate door on the gate you have pictured does look like a high speed pressure plate door.
Best,
-Tim
