How to make this light ?
Lighting
10 replies to this topic
#1 fouadelbali
fouadelbali
  • 30 posts
Posted 25 September 2013 - 02:49 PM
  • 20072 posts
Posted 25 September 2013 - 02:57 PM
That could be done with a Leko or ETC Source-4 Leko, probably with a iris in it though it may not be necessary if the lens alone gets you the circle size you need.  With a light that close and the beam so wide, it may be more than a 50 degree lens, like a 70 or 90 degree.
http://www.etcconnec...ang=us&region=1
There are also theatrical projector units that will create such spots, like a Vari-Lite:
http://en.wikipedia.org/wiki/Vari-Lite
  • 1
#3 Adrian Sierkowski
  • 7373 posts
Posted 25 September 2013 - 03:58 PM
Also to see the beam you need some atmosphere to shoot through-- a hazer would be quite helpful.
  • 1
#4 fouadelbali
fouadelbali
  • 30 posts
Posted 25 September 2013 - 06:39 PM
Thanks a lot David & Adrien That Was Very Helpful
Adrien How to create a good atmosphere with a hazer ?
#5 Adrian Sierkowski
  • 7373 posts
Posted 25 September 2013 - 06:43 PM
It's a matter of taste how much you want; but basically you turn it on before you roll and let it fill the space until you're getting enough definition on your light beam. Then you shoot. It'll dissipate as you go, so you'll need to re-fill the space with it on occasion.
  • 1
#6 fouadelbali
fouadelbali
  • 30 posts
Posted 25 September 2013 - 09:54 PM
Thanks Man
#7 jeff woods
jeff woods
  • 80 posts
  • Portland, OR
Posted 27 September 2013 - 04:26 PM
Based on the lack of blue hilation on the edge of the field, it look like a  26 or a 36; the 50's are really blue around the field (and also don't get as flat). The edge of the field also lacks the telltale "steps" of an iris in focus.
It also looks like it's coming from a balcony rail position, although not too far from the subject (the aperture of S4 lenses is about 6"; it looks smaller than that compared to his head size) . The ellipse of the field seems to be getting foreshortened by the perspective.
Is this a frame grab from something we could look at?
One man's opinion,
-j
  • 1
#8 David Mullen ASC
  • 20072 posts
Posted 27 September 2013 - 04:52 PM
Yes, it could be a shorter degree lens (narrower circle) if it were farther away, it's hard to tell in the photo.  Though I find that a 19 degree lens doesn't create as flat and even a field.
  • 1
#9 jeff woods
jeff woods
  • 80 posts
  • Portland, OR
Posted 27 September 2013 - 05:18 PM
Agreed. Have you played with the EDLT lenses? Pretty nice, and much higher contrast with patterns.
  • 1
#10 Kemalettin Sert
Kemalettin Sert
  • 84 posts
  • Digital Image Technician
  • Istanbul
Posted 27 September 2013 - 08:35 PM
Thanks for the tutorials in ASC :)
  • 1
#11 Stephen Selby
Stephen Selby
  • 79 posts
Posted 11 December 2013 - 10:26 AM
Dedo projection kit could probably do this.
