What atmosphere can I create with Kino Flos?
Kinoflo Interior lighting
#1 Mike Barlas
Mike Barlas
  • 7 posts
  • Ontario
Posted 08 October 2013 - 11:32 AM
Hi everybody
To clarify my older post.
I am trying to light a room that is 30ft long 16ft wide and 15 ft tall with three 4 bank kino's.
The room is wood and will be dark, except for some minimal house lights, 5x 30 watts halogens on the ceiling.Which I can change the bulbs to 150watts if need be.
I want to create a slightly underexposed background ambience, where details
are visible. But the room is NOT fully lit. Similair to this reference photo:
Ignore the color cast please.
I want to use the three Kino 4 Banks to light the background only, but
I wouldn't mind some of that background light spilling on the sides of the actors, such as in the photo.
Hope this makes sense.
Mike
  • 20072 posts
Posted 08 October 2013 - 11:46 AM
You'd basically have to rig them parallel to the long direction every six feet -- assuming these are 4' 4-bank Kinos -- so after 6', you hang the first one, then there's another 6' gap, then you hang the next Kino, etc.  If you have enough exposure, since you want a dim ambience, you could cover the outside of the Kino doors with diffusion like 216.
You'd probably still want a couple more Kinos on stands for lighting people in their closer shots.
#3 Mike Barlas
Mike Barlas
  • 7 posts
  • Ontario
Posted 08 October 2013 - 01:40 PM
Hi David,
Thank's for your reply.
Yes, these are 4' 4 bank kinos. Thank's for the rigging advice.
So i will rig the Kino's on one wall, and film our shots across on the other wall and middle of room say 10 ft away.
And diffuse as needed. I have some Lee 250 half white diffusion and 420 light opal frost.
I was concerned about the Kino light fall off.  At 6ft they produce 84fc or 775lux, but I have no idea what that will look like.
I will do a test but not under exact conditions.
For  the close ups of the actors  I plan to light them more dramatically. With  a 1k tungtsen fresnel and fill with a 650 watt tungsten fresnel with diffusion 250 doubled.
similar to this photo, but with longer shadows that are filled in more.
http://mimg.ugo.com/...per_480x480.jpg
I hope to use above set up for groups of three or four, but flood the fresnels more? I do have access to a couple 750 plus open faced fresnels...
Thank's again David, your time and input are much appreciated.
Cheers,
Mike
