Fluorescent Lighting from TL-D Graphica 950
#1 Chanon Wangtrirat
Chanon Wangtrirat
  • 35 posts
  • Bangkok
Posted 28 October 2013 - 04:20 PM
I made this one for filming for many projects in University.
Before I used some typical Flo-tube which give green spike on Daylight WB (5200K on Canon DSLR).
Later on I used Osram StudioLine 55/5600. Pretty great light but some how skin tone looks a bit off and cast Magenta (actually they maybe intended to used in studio just like there name for Chroma key lighting)
995869_10202504003992349_1290706755_n.jp
The most fascinated tube for me is TL-D Graphica 950 from Philips which rated at CRI 97 with CCT 5300K.
1146717_10201826302970247_1910535405_n.j
The picture is shot on Canon 60D
DIT 4ft 2bank TL-D Graphica 950
250W 5500K HMI also DIY
ISO 250 PS : N
F4.5 1/50 WB : 5200K
1377020_10202494040023256_664823581_n.jp
Matched perfectly with Daylight and give really good skin tone. I loved this more than real Kino bulb which sometime cast Magenta as they designed for higher power rated.
Thank you.
Edited by Chanon Wangtrirat, 28 October 2013 - 04:25 PM.
#2 Phil Rhodes
  • 12175 posts
Posted 28 October 2013 - 05:39 PM
What do they cost? Do they make the same thing in 4' 36W?
#3 Chanon Wangtrirat
Chanon Wangtrirat
  • 35 posts
  • Bangkok
Posted 28 October 2013 - 06:17 PM
Philips TL-D Graphica 950 is 4ft 36W T8 tube that design to used in household fixtures. It's printing colour inspection lamp which gave very realistic colour on D50 standard.
about $20 per tube
http://www.ecat.ligh...hica/21383/cat/
http://www.lightbulb...-950-4ft//p2771
Osram StudioLine 55/5600 use same base as Diva-lite tubes ,2G11 base
Philips also make 2ft 18W and 5ft 58W version.
Edited by Chanon Wangtrirat, 28 October 2013 - 06:21 PM.
#4 Phil Rhodes
  • 12175 posts
Posted 28 October 2013 - 07:00 PM
I flee in terror from $20 a tube when they're so alarmingly easy to break!
And I'd need 16 tubes to relamp all my stuff. Ouch.
I use protective sleeves on mine - not so much to protect them from being broken, which is difficult, but to contain the mess if they are damaged.
#5 Chanon Wangtrirat
Chanon Wangtrirat
  • 35 posts
  • Bangkok
Posted 28 October 2013 - 07:10 PM
Yes, It's really fragile especially with 4ft or more. I almost be a gaffer in the team, Look after this fragile stuff.
If you buy bulk of it. the price will go down as in Thailand here go as low as $120 per 10 tubes.
I've also look at some LED tubes but none of them offer quality light as I expected, Useless green cast and poor skin tone.
#6 Chanon Wangtrirat
Chanon Wangtrirat
  • 35 posts
  • Bangkok
Posted 28 October 2013 - 07:20 PM
This is on set with windows light which cast some green tint. Acceptable.
5200K WB 6D
1233066_10202299917410312_1997445343_o.j
#7 Matthew Parnell
Matthew Parnell
  • 289 posts
  • Electrician
  • Brisbane, Australia
Posted 29 October 2013 - 05:58 AM
The TLD-950 and TLD-930s are great tubes when filming in offices or anywhere you want to keep practical fluros on, but want don't want green/magenta casts. Have spend many hours swapping out domestic tubes for TLD950/930 tubes. They're a pretty nice match to kinos.
I wouldn't uses these day in-day out in kino fixtures, with kino balasts, as kino ballasts over drive the tubes(the kino tubes themselves are designed to be overdriven as opposed to a standard tube) and the rendering gets a little inconsistent once the tube gets hot. Also the fragility of the tube doesn't really lend itself to the wear and tear being used arround set.
#8 Phil Rhodes
  • 12175 posts
Posted 29 October 2013 - 06:28 AM
I use these.
I get the impression they're really intended to allow people to maintain standards required for food preparation areas - hence the blue - but they serve to avoid throwing glass and toxic chemicals everywhere if you break a tube.
They look tougher than they are - the plastic is very thin and you can compress the tube between a thumb and forefinger, so it's more about mess prevention than actually making the tubes tougher.
Yes, kino ballasts will make standard tubes emit more yellow.
#9 Chanon Wangtrirat
Chanon Wangtrirat
  • 35 posts
  • Bangkok
Posted 29 October 2013 - 11:36 AM
Wow! That's what I looking for. Thanks!
Also, Graphica is much greater continuous spectrum than normal TL-D 9XX. but as many used it's likely to be same.
