Light Levels When Bouncing
#1 Nick Centera
Nick Centera
  • 88 posts
  • 2nd Assistant Camera
  • San Diego
Posted 28 October 2013 - 09:51 PM
Hey, I was curious if the output when bouncing a light changes drastically when using different lamp sizes.  For example, if I bounce a 1k into an Ultra Bounce versus a 2k, or even a 1k versus a much larger unit, will the result be a brighter reflection or is there a max amount of reflection that will be released off the bounce?
Nick
#2 Phil Rhodes
  • 12161 posts
Posted 29 October 2013 - 05:30 AM
Reflective surfaces do not have a maximum potential loading, at least until they catch fire.
So yes, firing more light into it will result in a brighter bounce, more or less linearly.
#3 Benny Tan
Benny Tan
  • 10 posts
  • Orlando, FL
Posted 03 November 2013 - 09:04 PM
By using the ultrabounce, you're essentially creating another factor that affects the quality of the light. I'd like to say that the reflective qualities of your ultrabounce will play a similar role to the size of the light you're using. A bigger light will give you bigger punch, and give you a different quality of light. For example, moving your light source away from your subject and using a larger source will give you a softer look.
As Phil mentioned, the ultrabounce will bounce as much light as you throw at it until it catches on fire!  :wacko:
