Lighting interior tennis court
tennis court lighting
#1 Joseph Murphy
Joseph Murphy
  • 5 posts
Posted 05 November 2013 - 10:10 PM
I'll be shooting recruiting videos for high school tennis players that want to play college tennis. There is nasty overhead lighting and I'm trying to brainstorm a more attractive lighting setup. I will be renting the lighting equipment. Any suggestions on set up within a reasonable budget? I've attached some of the courts I will be shooting on. I will be able to turn off the overhead lights.
Edited by Joseph Murphy, 05 November 2013 - 10:14 PM.
#2 Zakaree Sandberg
Zakaree Sandberg
  • 26 posts
  • orange county,ca
Posted 06 November 2013 - 09:01 PM
turn off overheads.. fly as many 6x6 or larger frames of ultrabounce or maybe even a softer source.. hit them with each with 2ks
maybe 3 per side (replicate large tennis court lights)
this is the cheap way..
#3 jeff woods
jeff woods
  • 80 posts
  • Portland, OR
Posted 06 November 2013 - 09:16 PM
I'm curious what look you are trying to achieve; are you not wanting to make the indoor court look like an indoor court?
-j
#4 Adrian Sierkowski
  • 7488 posts
Posted 06 November 2013 - 11:36 PM
I would certainly turn off overheads- fly some kind of soft side source on people, and then back light with a good rim, and maybe bring in negative fill to kill bounce back and up your contrast range a bit.
#5 Mark Kenfield
Mark Kenfield
  • 1201 posts
Posted 07 November 2013 - 01:39 AM
The ceiling looks nice and white and reflective. You can probably improve things a lot by just switching off the overheads and firing a bunch of blondes or HMIs up into the ceiling for general illumination, then perhaps some extra lights bounced of umbrellas or through softboxes on one side of the court to give the players an edge light and pull them out a little.
#6 Stephen Selby
Stephen Selby
  • 79 posts
Posted 11 December 2013 - 09:24 AM
Overhead lighting can be a bit bland. So go for some directional lighting with softbox. Are you shooting a master to include all courts. If just using one end court you could potentially put up a large white screen - switch the lighting off on that court only, and have the ceiling lights from the other courts diffuse through your screen. But that might be too much work.
